Question about Kenmore 5365 Dehumidifier
When I plug it in it lights up but will not tun
  • Kenmore Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Sep 15, 2010
I plug it up display shows 8.8. and goes blank. Power light on top and side is green ON. Full bucket light and alarm works, timer button works, nothing else works.
Hello Ethan, thanks for your submission!
Based off what you have described your Frigidaire dehumidifier is displaying 8.78 after being plugged in. This could be an internal issue with a sensor or panel. You may need to contact your manufacturer for additional assistance. Good luck! -Matt
Apr 27, 2016 | Frigidaire Fdl50s1 Air Purifier &...
No lights on controls but power at theplug willnot start ?
? power at the plug, so power at the socket, but not in unit. check unit fuse in plug, check for fuses on unit, usually at back near to power inlet
Aug 13, 2014 | LG LD301EL Dehumidifier
I bought a model 365 remington dehumidifier. I plugged it in and nothing lights up. I have it plugged in for the past 8 to 10m hous and still nothing. Should i be seeing the blue light up ?
Two things that you need to check: Make sure that the outlet the dehumidifier is plugged int, is in fact working. The circuit breaker for that outlet may be tripped or there may be a loose or damaged wire connection to the one of the outlet's terminals. I assume you are turning the Master ON/OFF Switch to ON of the dehumidifier, after you plugged the unit in and set the humidity extraction level below 40%?
Jun 27, 2011 | Remington Model 365 Dehumidifier
THERE IS NO POWER OR ANYTHING WHEN I PLUG THE UNIT IN
check outlet
remove cover and check fuse on power supply board
Dec 25, 2009 | Maytag M7DH65B2A Dehumidifier
The bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
Oct 10, 2009 | Maytag M7DH65B2A Dehumidifier
No lights, won't turn on
I suggest checking the fuse on the circuit board.
Oct 19, 2007 | Kenmore 54701 Dehumidifier
The main switch is broken off and it does not turn on
You have to remove the entire wrapper to get to the control circuit board, make sure you unplug unit!! Locate the small white wires that plug into the board and go to the humidity switch.Unplug the connector at the board and plug the machine in and see if everything runs. ps make sure you reinstall the bucket or unit will not run. If machine runs replace that humidity control. The plug on the board is usually white. The other white wire is 4 the light. I hope this helps./
Sep 05, 2007 | Goldstar DH304 Dehumidifier
No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Sep 19, 2006 | Haier HDN655E Dehumidifier
Dehumidifiers Logo
81 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
