Question about Vacuums
Mosquito Swatter is Not Working YPD Model:LTD-006
2 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: YPD MOSQUITO BAT IS NOT
Battery voltage low? To test a battery you need to place a load on it to get the true reading of the power left in it. A straight test with a volt meter at no load is a misleading indication and will almost always give the battery rated voltage, even though the battery is almost dead.
Posted on Apr 06, 2011
I am trying to find out the size of the filter. The model is C 2006P. It also does not have a brand name, only a D on the side. It takes a cyclone shaped filter
Mellisa, searched the net, very little info. suggest you take vac/filter with you and stop by a vac/repair shop who will be able to see if it matches other models and can set you up with replacement filter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 27, 2016 | Filter Vacuums
I have a vax compact bagless upright vacuum cleaner - model No. X-006 and the wheels keep coming off and each time I replace same after a very short while they come off again
These wheels usually are fitted by means of a number of lugs 3 or 4 on the back of each wheel and they are a press fit into holes in the vac body. If one of the lugs is broken or cracked at the base whe wheel wont stay on. I have repaired these with epoxy resin on the inside of the lugs but to be honest repairs don't last long.
Oct 20, 2014 | Vacuums
Need Manual
Hard to find - made by wisman technology co ltd in China
closest I came to it is a sales reps contact page
http://grace86311.en.ec21.com/
Grace maybe able to direct you or sell you a user manual
Sep 16, 2014 | Vacuums
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
YPD MOSQUITO BAT IS NOT HAVING SUFFICIENT VOLTAGE AT IT'S NET TO KILL MOSQUITOS.PL. GIVE REASONS
Apr 06, 2011 | Vacuums
LOOKING FOR SERVICE IN KEW JOHANNESBURG SOUTH AFRICA
Company: Electrolux South Africa (PTY) LTD Address: P.O. Box 3567, ZA-2000 Johannesburg Tel: +27 (0) 860 234 481 /2/3 Fax: +27 (0) 860 234 329
Jan 17, 2011 | Electrolux Central Vacuum
Part that locks vacuum in upright position, I cannot find
I have the exact same problem as you described it. I was hoping to find this plastic part reading 38719-006, and it seems it is not available as a part by it self. The attached image includes both the part you will need to purchase 43516010 along with the sub part circled.
Its a shame that this sub part isn't available by it self, but you can't have everything. The major part sells from about $16-25 with shipping on the net.
Nov 30, 2008 | Vacuums
Hi I have an electrolux "The Boss" hand held vaccum cleaner. I cannot find the instructions and am having problems changing the belt. It is model number Z57A. Product Number 900-250-006. It...
You need top lace belt on brush roller and re[-assemble by putting plastic cover on which is retained by 2 recessed philips screws.. Prize off triangular coverat fornt.behing that you should see the belt lying loose.You need to get a blunt object to twist and push belt ovet the motor shaft. You may get it on in wrong direction and if you do,loosen off belt and twist the other way.
Jul 12, 2008 | Electrolux Vacuums
Vacuums Logo
300 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
