Question about Garmin 12CX GPS Receiver
Replace the VL 1220 memory battery
Hello, I need to replace the battery on the 12XL but I don't know how to pull the case apart. If it's not too much trouble could you please explain this proceedure.
Thanks Mike in Homestead
  • Anonymous Nov 18, 2008
    i have the same problem
3 Suggested Answers
  • 5 Answers
SOURCE: Memory Battery Died in my
Wildstreak, same happened to my GPSMAP 180. Its old and no longer supported by Garmin. I did call them and they gave me the model and number of the battery (mine is a Panasonic) Also advised that units are heat sealed so I am taking mine to a local electdronics shop that also sells Garmin and have them replace the battery.
Seadrive Joe
Posted on Aug 29, 2008
SOURCE: What sort of internal memory battery is in my garmin 12xl?
You can find the battery here:
http://www.mouser.com/Search/Refine.aspx?Keyword=658-VL1220-1VC
To open the case, scrape the sealant in the grove around the unit; then use a flat screwdriver, as wide as possible, that fits in the grove. Place the screwdriver on all sides and different places. Rotate the screwdriver gently until the glue tears and both gps housings can be separated.
To replace the battery you will need to be handy in soldering in tight spaces.
Posted on Mar 30, 2009
Hello. I used to own a SHARP VIEWCAM Camcorder (model# VL-E650U). I lent it to someone & never received back. I would like to know if there is any other product/device that I can use to play/view the...
Want to buy my VL-E650U Sharp Viewcam? Selling bag, camcorder, 3 tapes, manual, remote, and two batteries. Although the batteries don't hold juice very long any more, all the other items are in great shape without blemishes. Liz
Jun 17, 2011 | Sharp VL-E650U 8mm Analog Camcorder
I am getting a Memory Battery is Low - how do I recharge or replace teh memory batter. I only load AAA batteries into the equipment?
The memory battery is normally charged by the AA batteries. Leave the batteries in for 5 days. If this doesn't recharge the memory battery then it needs replacing. It's recommended that you send the unit back to Garmin to have it replaced. The memory battery is a Panasonic VL 1220. If you want to attempt changing the battery yourself there's some information on how to do so at http://forums.groundspeak.com/GC/lofiversion/index.php?t38975.html
Nov 08, 2010 | Garmin GPS 12XL GPS Receiver
I need to replace the CMOS battery in my Gateway 7330 laptop and I cannot find out where it is
It is just below the keyboard under the palm rest. Remove all of the screws from the bottom of the unit, carefully - from the left side, pry up the trim panel that has the power button (careful since the power button board is screwed into this panel), then remove the screws for the keyboard, slide it up towards the LCD to release it, remove its ribbon cable, you should be able to gently pry the upper and lower case halves apart enough to see the battery. The cases will NOT seperate!!!!!!!!! I then used a small straight blade screw driver to pop the battery out. It was a CR 1220 3v lithium coin type battery in my 7330GZ. I had to go to a specialty battery store to get one! Hope that this helps!
Nov 05, 2010 | Gateway 7330GZ (890552601318) PC Notebook
When i open garmin 12xl it gev me vois when i press page bottom this message show me (Memory Battery is Low ) how to solve this
The memory battery is a BTR2032 or a CR2032. This is one of those coin type batteries. To replace it you need to open the case and depending on when your unit was made you will either find a battery hold or the battery will have wires soldered to it.
The batteries are cheap. Usually under $1. Getting someone to change might cost a bit. If this battery goes out then your unit will forget settings and so on and have to reload everything from scratch every time you use it. It will work fine but might take 5-10 minutes (depends on how many sattilites it can see) to get running.
Oct 10, 2010 | Garmin GPS 12XL GPS Receiver
2003 Saab 9-3 Arc - Need to replace key battery
Squeeze the logo and pull up on the "ring" to seperate the "key" from the pod. Then insert the key n the slot and turn to pry apart the pod. The battery is inside of the pod.
May 01, 2009 | 2004 Saab 9-3
Lost destination after saving it
Sounds like the internal memory battery is run down - it's charged from the AA's. Usually does not recover. Battery (the VL1220) is shown here: http://www.panasonic.com/industrial/battery/oem/chem/lith/vana.htm.
It' easily replaced once the case is open but requires a steady hand with a fine tip soldering iron. Local story started by me here.
Sealing the case up again is very fiddly - hard to make a tidy job with silicone.
Feb 22, 2009 | Garmin GPS 12XL GPS Receiver
Memory Battery Died in my Garmin GPS 12XL...Can I replace it?
Seadrive Joe
Aug 29, 2008 | Garmin GPS
Mar 24, 2008 | Garmin GPS 12XL GPS Receiver
Corrupted data
Canon S400 IXUS 400 ? The fix for ?memory card errors? The only tool you need is a small ?jewellers? cross head screwdriver. the procedure is not difficult but you need to proceed with care on a well-illuminated, flat, plain surface. Switch off then remove the rechargeable main battery and the memory card. Now remove all the small screws around the casing. These screws are of different lengths and it is important to lay them out in a logical manner so that later you can replace them correctly. If you use a teatowel to take it apart on the screws won?t roll away. Note Do not remove the main rechargeable battery release catch. It's a MAJOR job to put it back together. Carefully separate the halves of the casing. The lithium battery is at the front under the bottom right hand corner of the copper coloured flexible shield. The internal disk-shaped 3-volt lithium battery is about 6mm across. Be careful to disassemble the bare minimum necessary. If you see a spring popping up, you are disassembling too much. Remove this battery, taking care not to touch the side and bottom simultaneously with a metal implement. After about ten minutes, replace the 3-volt battery. Reassemble the metal case taking care that the sliding switch for the take/review function is correctly located. The 2 halves of the case fit perfectly, if you can see any gaps you need to just check the overlapping metal plates are fitting together properly, you don?t need to force anything. Be sure that the rubber jack socket cover - is seated properly whilst you reattach the rear part of the case. Replace the main rechargeable battery and the memory card. You will have to reset the time and date data as they are deleted when the 3-volt battery is removed. You may find the video replay system has to be reset If you don?t get the date/time screen after switching back on you have not left the lithium battery out long enough. You should find most user settings and, the last image file number are kept. Too scared to try this? You can leave the main battery out of the camera for at least a month and the small Lithium will run down and eventually reset itself. By the way Canon know about this fault and should fix it for free but the notice is well hidden on their site and if you don?t know about the issue they will bill you for the ?repair? Firefly With thanks to the people on dpreview.com forum who helped me solve this one.
Oct 02, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Garmin 12CX GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
