Question about Sony KDF42E2000 42" HDTV
Where can i find the ballast for my tv? - Sony KDF42E2000 42" HDTV
  • Sony Master
  • 8,457 Answers
Tries websites like Partstore.com,Ebay.com to buy a Ballast board.
Posted on Sep 15, 2010
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
How do i install a new ballast for projection lamp ballast in mitsubishi model wd 52327
Not sure if this is your TV for it don't specify a model of TV, only stating a V41 Ballast
https://docs.sony.com/release/KP53S75.PDF
This video specifies nothing but goes more in depth w/audio
https://www.youtube.com/watch?v=5frOnh58Z6M
TV's shown are different but the ballast part is the same (location and cables).
Dec 11, 2014 | Mitsubishi Televison & Video
How to tell if ballast is bad on samsung dlp tv
It is a common practice that the ballast to repalce along with new bulb. There is no way to check the internal winding short of ballast. Repalce both at the same time. If ballast has any damage, it will surely ruin the bulb too.
Jun 04, 2012 | Samsung HL50A650 50 in. TV
My 50in LCD has had a green tint to it for several months, was told by Best Buy that it was likely that a mirror got misaligned when we moved. Friend had the exact same tv...thought that the bulb went...
Good luck with that.... But if you really want to try,... look at where the bulb makes electrical connection when it is plugged into the set. You should see two thick wires leaving a connector and going to a circuit board. this board is the ballast. You'll have to disassemble until you can get the board along with the wires and connector.
Aug 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
KF42WE610 bad lamp... and ballast?
DLP Lamp has electrodes inside and ballast generates high voltage that makes spark on these electrodes thus got high bright light. New lamp wont die due to bad ballast so replace lamp and see tv works or not.
This tv has self diagnostic feature, turn On tv and let it shut down, now check standby light that would be blinking in specific order, for example 3 or 4 times blink then pause for 3 seconds and again blinks.
Let me know how many times standby light blinking in this tv to help you with more info.
Thanks.
May 16, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Where is ballast located
FOX has Lamp for $109.00 1-800-227-5369
Encompass Parts has Ballast $54.43 1-800-638-3328
Encompass wants $150.00 for lamp Your TV is a Samsung it will be on Right Hand Side of TV and I would Just Replace The Lamp First? What was your TV doing to begin with?
Dec 31, 2009 | Televison & Video
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
TV WILL NOT POWER UP
The ballast uses open ended high voltage. Both the start current, and the running voltage must be verified.
Normaly the ballast is replaced unless you have the test jigg which is essentialy the specified lamp simulator.
If there is a sensor fault that indicates there may be a potential cooling problem, or an unsafe fault condition (bad socket), or if the lamp is sensed as being defective, the ballast will be shut down.
Jerry G.
Apr 17, 2008 | Samsung DLP HL-P5663W 56" TV
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
My projection tv
Nov 23, 2007 | Samsung HLN5065W 50" Rear Projection...
Sony KDF42E2000 42" HDTV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
