Question about RCA Televison & Video
My RCA Entertainment series TV won't turn on. The l.e.d. on the power button blinks like it's turning on, but then goes out. This happens 3 times then stops, and the TV is not on. Is this a fixable problem? or is my TV broken?
3 Suggested Answers
SOURCE: Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Posted on Jun 23, 2008
SOURCE: 27 rca entertainment rca series tv some sound
UNPLUG THE TV FOR A FEW MINUTES...IT RESETS THE TV
Posted on Oct 29, 2010
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
May 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
Aug 07, 2008 | RCA D52W19 52" Rear Projection Television
Green blinking power button
Sounds like an internal fuse or a power supply problem. It is worth it (I don't normally say this) to get this set fixed.
Jun 25, 2008 | RCA F36650 36" TV
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
RCA P52920BL
F32 or F36650 = same transformer = 257805 or Asti 2078
P52920BL = need service number = P52920BLXXX then I will
confirm flyback part #..................................T.
Dec 26, 2007 | RCA F36650 36" TV
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
Televison & Video Logo
137 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
