Question about Beverage-Air 11.8 cu. ft. / 334 liter Commercial Freezer BEVWTF-48
Freezer not freezing acting like refrigerator
  • Beverage-Air Master
  • 43,501 Answers
Either the thermostat went bad or the refrigeration system has a leak and you are low on freon....that will also cause poor cooling..
heatman101
Posted on Sep 15, 2010
Refrigerator and freezer is freezing everything
Its either a bad defrost timer not kicking on, bad main control board or the temp switch. Sorry not much help but the only way to really tell is check with a ohlm meteor and eliminate each part.
Mar 04, 2015 | Kenmore 26.5 cu. ft. Side-by-Side...
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
25328782800 freezer not freezing 2 lites blinking
The problem your refrigerator has sounds like a 297370602 Main Control Board
Can you unplug refrigerator and go into the control panel inside the fresh food section? Examine the board for burn marks and swollen capacitors. I will be here if you have questions, Sea Breeze
Feb 08, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The freezer side of the unit will freeze until it freezes over and will no longer keep the freezer frozen. The freezer then has to be defrosted so it can freeze again.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Maytag Freezers
Freezer not freezing ,compressor working power on etc
This one you have to get access to the refrigeration system to see what operating pressure you have to determine if there is enough freon charge to freeze. you need a tap valve and refrigeration gauges.
Mar 30, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
FRIGIDAIRE FREEZER MODEL # LFFU1465DW3 WON'T FREEZE
Make sure freezer door seal is completely sealed. No gaps, Also, if you are up to the challange, you will need to remove the freezer panel, test thermometer, thermostat, for voltage and resistance. Also check that the flapper that seprates freezer from fridge air.; Is not frozen.
Jun 11, 2009 | Frigidaire Freezer Refrigeration White...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Beverage-Air 11.8 cu. ft. / 334 liter Commercial Freezer BEVWTF-48 Logo
82 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Michael Youngman
Michael Youngman
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
