Question about Microwave Ovens
Do you have glass microwive model bmo 700 (17 lt)
  • Microwave Ovens Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 15, 2010
Powergard inverter 1000w nn-cd987w
Fixya does not sell replacement Powergard inverters.
Oct 19, 2016 | Panasonic Microwave Ovens
No rotisery and cooking power
Check diode ( this connects to the casing of microwave) , the transformer, then the magnetron in that order. Turntable has separate motor and the spindle that fits onto oven plate are prone to breaking.parts are replaceable and can be bought off eBay for approx £24
Jan 13, 2015 | Sharp Electronics Corporation SHARP 1000W...
JVM 1790sk01
Cook using microwaves or convection in this stylish microwave oven that allows your food to be flavorful beautifully browned and cooked quickly .now your microwive didn't work .you should take it to fix .
home light bulbs
May 03, 2012 | GE Profile Spacemaker Over-the-Range...
How do you change the light bulb in microwave
Hi, concerning your microwave. The wrap around case on this unit has to be removed to get to the light bulb. Be sure the microw. is unplugged. Hope this helps.
Jan 18, 2011 | KitchenAid KCMS135 Microwave Oven
Won't heat/cook food, otherwise appears fine
Hi, am assuming the microw. runs. The problem is in the hi-voltage section. The magnetron has a five year guarantee. If it is, you need to contact a local factory authorized servicecenter. If out of warranty, you need the magnetron, hi-voltage transformer, diode and a capacitor to get this unit up and running again. If I had the model number, I could send you the part numbers. Hope this helps
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have 3 years old Panasonic microw wave model NN215MF. When I switch it on, there is seems to be no response, it does not light up and remains silent as if there is no power. Kindly help. My email:...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 09, 2010 | Panasonic Microwave Ovens
I have BPL Sanyo Microwave appliance, Model No.BMO 700T. Despite power On & display, the motor & cooling fan is not working. Can you please let me know the detailed solutions? Also, can you...
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
The cooling fan and turntable motor get their supply from the same point as the main transformer. If the magnetron or diode has failed that will cause excess current to be drawn and take out the supply fuse.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 23, 2010 | Microwave Ovens
Broken Handle on GE Spacemaker XL
It looks like the current part number is WB15X335.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I nee some help with my microwave
It's on the parts list under door parts.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
May 06, 2008 | Microwave Ovens
Microwave Ovens Logo
157 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
