I disconnected the wireless router while moving and can't remembr how to reconnect
    Problem Solver:
  • 17 Answers
Plug the power into you modem first and wait for it to fully boot. Then plug in the Ethernet cable from your modem to your wireless router into the spot that is specified for modem/internet(usually the port that's by it's self). It will take about 1-2 minutes for your router to fully load which at this point you should be able to connect to your WiFi network or if needed connect another Ethernet cable from any of the other 4 ports on the back of the router to your PC or device.
Posted on Sep 15, 2010
Why does my acer aspire 5315 wifi keep disconnecting and reconnecting?
hello sir.
Reason :-
1.Make sure your acer aspire is in range.
2.cheack is it your wireless disconnecting and reconnecting or is it your internet disconnecting and reconnecting.
3.Are you facing this issue with any other machine or is this the only one.
If this is the only computer in which your wifi connection is dropping then there is issue with wireless connectivity.
solution:-
1.Turn of your router and modem and then check the wireless connectivity.
If issue still persist then:-
2.Create a new network name and wireless security key and then connect to it:- Now check the wireless stability whether is it still disconnecting an reconnecting or is it stable now.
If issue still persist then bright your laptop close to router and then check wifi disconnecting any more or not if not then change the channel to 1 or 11 from your wireless router page.
Let me know if this worked for you or not.
If worked then please rate my solution.
May 25, 2012 | Acer Aspire 5315 Notebook
Randomly disconect wireless internet
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 27, 2012 | Gateway M-7315U Notebook
Unable to connect to the my wireless Internet
Try "rebooting" your internet. If it's fed through a router, disconnect the power to the router, as well as all of the connections, then reconnect them. Re-connect the power last.
Also, try moving closer to the source of your wireless internet. Sometimes the Dsi won't pick up on the signal because it has a weaker wireless receiver than a computer or most devices that will connect.
May 19, 2011 | Nintendo Dsi Pink Console
My netgear wndr3400 wireless router disconnects about once every hour. I must then manually reconnect to the router. How can this be fixed?
change the channel selection in the wireless settings from auto to a any one of the channels on the drop down list. I actually did it by trial and error until the i found a channel that works. Also if you have the router on the ground floor of a multi floor home the signal range is lousy, move it to the second floor and keep it away from places where they are too many electrical devices close by maintain at least 6feet of distance from televisions and speakers and the range will be excellent
Feb 02, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
WRT54G keeps disconnecting itself, requires disconnecting/reconnecting power and running setup disk again to reconnect. System info: 12 mb/s cable broadband ISP, Motorola SB5105 cable modem, WRT54G...
Go to Administrative Page on your router at section Setup - Basic and activate: Keep Alive : Redial Period 30 seconds.
After that restart your router
Mar 04, 2010 | Linksys Wireless-G WRT54G Router
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
I cannot connect to internet with ps3 using belkin g plus mimo..
you might need to disconnect your modem for 30 secs then reconnect it . i have just reset my router and then the pc would show a connection but it only went to the router not through to the web.disconnect your modem reconnect then do a reconnect on the pc
Aug 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ami - speed touch router
Try changing channels on your wireless router. Routers have configuration page where you can change the channel. Refer to your user manual on how to change the channel on the device.
You may also try moving the router to a different location or maybe on a higher location. To avoid interference.
Oct 18, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
