Question about Motorola T8500 Two Way Radio
Cannot hear transmisions all the time. changed batteries to regular alkaline from pack to see if the battery were bad. this did not change the transmissions problem. need help.
  • Foodcritic25
    Foodcritic25 Sep 15, 2010
    What is the distance between you and the other Motorola T8500 Two Way Radio
  • Motorola Master
  • 1,654 Answers
You may have one of the following issues:
1) Programming of special features is inhibiting communications. Reprogram the radio(s) back to a basic mode with the special features, code and Qt filter (if any) turned off (zero). Then check to see if communications improves.
2) You could have a Transmit problem with the other radio. This could be caused by a bad or low battery or even a sticking PTT. Try trading the batteries with a known good radio and see if the problem changes or moves to the other radio.
3) Your radio could be failing. If you have changed the batteries to known good batteries, and tested the radio with more than one other radio, and you do not have a programming problem, you likely have a radio which is failing.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Sep 15, 2010
I was looking through some box's and i found this camera. i put in two regular AA batteries and it worked fine, now its not even turning on. I tried changing the batteries.
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Apr 13, 2015 | Kodak EASYSHARE Z1485 IS Digital Camera
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
My Kodak Easyshare Z1275 has short battery life. sometimes even newly charged 2600 MaH batteries cause problems. Powers up, lens extends, opens screen to set time and date then powers down. Sometimes i can...
wait, do you have Li Ion batteries or Ni MH?
I think that Kodak recommends Li Ion batteries which have a higher voltage on them.
I got some generic Li ion battery packs off of Amazon.com, with better specs. than Kodak, and they work fine for my Easyshare z1485 IS camera.
It cost me like $80 to get the charger and two battery packs that are Li Ion, but it's worth it.
My battery packs are rated at 2000 mAh 3.7 Volts each. It's the voltage that counts. You see, if you would split that in half, the voltage for each AA battery is 1.85V which is much higher than the 1.5V that regular Alkaline or Ni MH batteries are rated at.
I tried Alkalines, and Ni MH to no avail. But, the Li Ion batteries, did the trick for me.
Good luck on this 'repair' or battery upgrade.
Jul 23, 2010 | Kodak Cameras
Vtech Kidizoom camera. Have changed batteries but unit is not even switching on. Son has had for just over a year and it has been dropped several times.
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Jan 06, 2010 | Vtech Kidizoom Digital Camera
Batteries drain after only 5 or 6 pictures
New camera?...take it back.
Aug 25, 2009 | Cameras
My Canon S2 IS keeps saying 'change the battery' even if I put the new batteries in. Why...? Thanks.
there is a little coing battery located inside the battery compartment for the AA's. CR1220 you can get this at Radio Shack for about $5. If this battery is bad you will get the change batteries screen no matter how many fresh AA's you put in, Use a good quality alkaline battery such as the Energizer rechargable rated at 2700 mAh.
Jul 04, 2009 | Canon PowerShot S2 IS Digital Camera
Charging batteries
the cobras are meant to work with alkaline cells. You bought nicads which are a lower voltage per cell (1.2 to 1.38). Alkalines are about 1.55-1.58
That is why your rechargeables only show a quarter charge, because their terminal voltage is lower and the radio thinks they are not fully-charged.
May 28, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Sir my sonyDSC-40 Camera dot't power on. In power butten pressing time only one time bliking green LED.
Turn off the camera, remove the battery pack. Allow the camera to remain without power for 30 seconds. Reinsert the the battery pack. Turn on the camera.
Please make sure the Battery is fully charged before performing this steps.
Also try changing the Batteries of the Camera. "AA" NiMH, "AA" Alkaline, "AA"
Nickel-Metal Manganese are the compatible Battries for the Camera. Hope it works!
Dec 01, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera will not power on
Are you making sure that you are using Alkaline batteries? Regular batteries won't work. Even rechargables will only work if you first put in alkalines and change the battery type in the menu, then put in the NiMH batteries (not NiCads).
Mar 22, 2008 | Samsung Digimax S730 Digital Camera
Motorola T8500  Two Way Radio Logo
146 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
