Question about Kenmore 62872 Electric Dryer
Model 110.66862501 - Series 80 Dryer I replaced the heater element and I put the connector wires on the lower thermostat on wrong. When I plugged in the dryer, the house fuse tripped. Now I believe I have the wires correctly connected to the lower thermostat. When I plug in the dryer the heater element turns on and stays on. When I push the button to start the motor, I get a buzz and the motor will not start. Please assist
  • sslyman Sep 15, 2010
    Jahn27:
    Regarding the heater staying on. I checked the elements and they don't appear to be touching anything. Is it possible that I shorted the lower thermostat when I connected the wires improperly? And would this cause the heater to stay on?
    FYI, I didn't see the wiring diagram image in your response. Please provide if possible.
    I will perform the other diagnostics tonight and report what I find.
    Thank you for your prompt response.
    Steve
    President:
  • 1,554 Answers
The thermal fuse on the blower housing is most likely blown resulting in the motor not running. Unplug the dryer and disconnect the thermal fuse wires and tape them together or jump a wire between them to bypass the thermal fuse. After the thermal fuse is bypassed, plug the dryer back in start it. The motor should start if the thermal fuse is indeed blown and needs to be replaced. Otherwise, the problem is either the timer, motor, or start switch which will need further troubleshooting to determine exactly which among them is the culprit.
Regarding the automatic turning on of the heating element,it is obvious that there's a short circuit or wiring fault. The heating element only turns on when the motor is running because of the centrifugal switch for the heating circuit that is activated by the motor.
Check to make sure that no part of the heating element coil is touching its housing. The heating element turns on automatically when the dryer is plugged in if a coil part touches the housing. Review the wiring connections by referring to the wiring diagram and the illustration below. Take note of the wire colors in the diagram. Only the initial of the colors are used to label the wires in the diagram.
Please accept the solution if you find it helpful or informative. Accepting a solution cannot prevent you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 15, 2010
  • 9 more comments
  • Jahn27
    Jahn27 Sep 15, 2010
    My apologies for the images. Here they are:
  • Jahn27
    Jahn27 Sep 15, 2010
    The cycling thermostat is also the operating thermostat.
  • Jahn27
    Jahn27 Sep 15, 2010
    As you can see, the thermostats and the thermal cut-off are wired in series with the heating element together with the timer switch and the centrifugal switch. The function of the thermostats is to interrupt the power to the heating circuit to regulate the dryer temperature. Shorting them simply disables that function but will not result in automatic turning on of the heater as long as the timer switch and the centrifugal switch are not shorted.
  • Jahn27
    Jahn27 Sep 15, 2010
    Here is the missing right part of the wiring diagram.
    Ok, I will double check the heating element and perform the thermal fuse diagnosis and get back to you tomorrow morning.
    You have been very helpful.
    Thanks
  • Jahn27
    Jahn27 Sep 15, 2010
  • sslyman Sep 16, 2010
    Jahn27,
    I did the Thermal Fuse test above and the motor still does not start. When I turned on the dryer there is a buzz coming from the Start button and the timer has a clicking sound.
    I also did a continuity test between the thermal fuse posts (w/o the wires attached) and there is a complete circuit.
    I double checked the heater element and it is not touching the housing - and still starts as before.
    FYI, I don't detect a burnt smell from either the start button or the timer.
    Any advice is welcome.
    Thanks,
    Steve
  • Jahn27
    Jahn27 Sep 16, 2010
    Perform a resistance/continuity test between each of the heating element terminals and its housing with and without the wires. The resistance/continuity should read infinite/open if there's no issue withe heating element shorting with its housing or no any other part of the heating circuit shorting with the cabinet.
    Regarding the motor not running, check to make sure the circuit breaker, where the dryer is connected, is not tripped. Also verify whether the buzz is coming from the timer, start switch, or the motor at the bottom of the machine. If the buzz sounds only when pushed, then it is likely that it is coming from the motor.
  • Jahn27
    Jahn27 Sep 16, 2010
    Better also check the condition of the motor and the centrifugal (motor) switch. Sometime the motor clamps can get loose and be lodged into the centrifugal (motor) switch and complete the heating circuit even the motor is not running.
    Jahn27:
    The dryer has one circuit breaker in the basement panel (it must cover both functions). The buzz is coming from the start switch. The timer clicks. There is no sound from the motor.
    It appears that I shorted either the motor or the timer switch when i connected the new heater element wrong (my error). Both are expensive so I plan on getting a new dryer unless you think otherwise.
    I appreciate all the help and expert advice.
    Take care,
    Steve
  • Jahn27
    Jahn27 Sep 16, 2010
    I cannot see the possibility of shorting the motor or the timer if you touch just the wiring of the components on the heater assembly. Please summarize from the very beginning what you did and what happened. so that I can analyzed and deduce what happened.
I changed the heating element in my whirlpool dryer (older model). I replaced it but the wires to the element and the wires to the thermostat are similar. 3 are red and 1 is red with a white stripe. I am...
there should be a red and then a red and white wire going to the element and the wires going to the element are thicker than the t-stat wires,also if it's an older machine if you just let the wires hang free they should almost line up to where they should go because they've been in that position for a while.
Nov 11, 2017 | Whirlpool Dryers
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My 80 series electric kenmore dyer runs but no heat
MY dryer has no heat
** UNPLUG a dryer before attempting ANY repairs. Lethal!
A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater.
Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire.
Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix.9df7975.jpg
Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Apr 17, 2010 | Kenmore 62602 Electric Dryer
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
I'm trying to install a new heating element to my Kenmore dryer 80/90 series. The rear panel does not come loose after I remove all the screws. I need this to come off to install the heating element. Tks
Replace screws at rear exactly as they were. Entrance for this dryer is at the lower front panel.
Unplug unit first. Place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the panel. This will release the lower panel and give you full access to all the main components.
The heater is on the right in the metal can with the cover at the front. On the left side of the can is a thermal fuse that may be open to turn off the heater. There is also a thermostat that may be bad or interconnecting wiring. Remove cover at the front of the can and disconnect wires to element.Element should slide out for replacement. Look for screws retaining it if it doesn't.
Reverse above process for reassembly. Good Luck.
Sep 10, 2009 | Kenmore 63942 Dryer
Replacing heater element
on your old heater there was a "thermostat, mounted to the lower end of the heater correct?? youllneed to remount that to the new heater( one end will gp to one terminal on heater) ohter "thick wire" goes to the other heater terminal, and on eto the open thermostat connectore, the last wire should be smaller in size and connect to teh side of the thermostat you just installed
Jan 21, 2009 | Whirlpool LEQ9858P Electric Dryer
Heating element for kenmore dryer won't turn on
Hi, I have an 11yr old 80 series elec. dryer and just fixed the same problem. On the heater element is a thermostat with 2 wires and above that about 14" is another piece with 2 wires. I had to replace the top one. They sell them together in a kit called Thermal cut off kit. Sears sell it for 25.49 look up part number 279816 or 3399848 again these numbers are for my dryer but you can look them up on the sears parts web site. If you have a sears service center near by they let me buy the parts to see which one it was and then return the ones I didn't need. I hope this helps.Good luck
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Roper dryer will not heat after replacing element
did you ck the thermal fuse located at top of element housing it may be blown..also if you have only 1 wire to element other leg of element should be attached to lower thermostat by a wire or short metal connector
Nov 15, 2008 | Dryers
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Kenmore 62872 Electric Dryer Logo
633 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
