Question about XFX GeForce FX 6800 (256 MB) Graphic Card
Monitor goes blank when login screen comes....
Sir,
My system worked properly previously. I uninstalled some programs in Add/Remove programs in control panel. After that, my system felt very difficult to show the DVD videos. I got an idea to reduce my hardware acceleration in the display properties with the help of Trouble shooting. After i reduced my hardware acceleration to low, my system got restarted. Now it doesnot showing anything after the XP logo. But it is logging in the background.
    Genius:
  • 2,785 Answers
Boot in safe mode and remove the display driver and reboot in normally
Posted on May 16, 2008
THE SYSTEM IS CONNECTED DIRECTLY INTO THE RECEIVER THAN INTO THE MONITOR. AS FAR AS I KNOW IT IS NOT CONNECTED TO MY INTERNET.
one thing that you can do is turn on the auto login feature if the screen goes blank or the login session times out. I am not aware of any reason why the system would time out. The auto login setting will log you in in the event your screen goes blank.
Jan 08, 2017 | The Audio Players & Recorders
Compatible with MS Office 2013 and Windows 7
Go to safe mode and uninstall the application or restore system
Press f8 while booting up to get into safe mode...
Dec 21, 2013 | Dell E173FP 17" LCD Monitor
Monitor comes on for 2 seconds then goes blank
Check if the cable connecting your monitor from the video card is properly secure and not loose...
You can also try this... turn off your cpu..remove the cable from your video card.....Open the housing....remove your video card from your motherboard... clean the contact surface of the video card with moisten cloth.... after cleaning...connect the video card to the motherboard...attached the cable to your video card.. close the housing and try to boot again...
I hope that work.. if not my suggestion is you try your video card in other computer, try also the monitor to other computer.. to see which one failed.
Much appreciated if you rate this help.. thanks..
May 23, 2010 | Samsung SyncMaster 920NW Monitor
Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Feb 07, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Cmi8738c3dx sound card causing PC to hang up to welcome/logon screen
Check whether the sound card drivers compatible with your present operating system. if your Pc built with Vista OS. then Get a vista driver from its official website.Some times When you install any devices or driver that might change the system files. even it may corrupt the files due to its incompatibility. Some mother board and Bios does not support some type of Sound cards . if your Motherboard has onboard audio .then disable it through Bios utility. uninstall the sound card,drivers. Remove the Sound card. REplug it. Restart the Pc. this time you can get add new hardware window. install the drivers. if problem still persists contact service centre.
thank you !
Dec 24, 2007 | Genius Soundmaker Value 5.1
XFX GeForce FX 6800 (256 MB) Graphic Card Logo
152 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
