Question about Refrigerators
Mine in samsung fridge model RS20nams. both side of the fridge is freezing ice cold. how to control the temperature?
  • 2,973 Answers
Nasir, If the fridge is still freezing after turning the thermostat to lowest then the thermostat is gone. Please replace it. In any case it is the thermostat that is bad in the fridge portion. The freezer should be OK.
Posted on Sep 15, 2010
Water Dispenser Temperature Control/switch-off
Not on regular models. Most models have a water tank in the fridge compartment which makes the water temperature to stay just above freezing temperature.
Wanna a play with your unit. Then remove the tank and just add two pipe ends together. Eliminating the tank. Then you should get room temperature water after about 5 seconds of cold water. Be careful just connecting the two ends of pipe after removing tank might lead to freezing pipes if your fridge temperature is close to freezing temp.
Nov 26, 2013 | Samsung RF4287HA
Tip
Refrigerator is Too Cold and Freezing Food
<p>When the <b>refrigerator side is getting too cold</b> this is because the <b>control of the compressor</b> has gone bad in some way...<br /><br />There a few different things that could cause the unit to lose <b>control over the temperature</b> of the <b>fridge</b> side.<br /><br />If your <b>refrigerator has a damper door</b> that opens and closes to allow cold air to move to the fridge side the damper linkage or the <b>damper motor</b> may have broken or gone bad.<br /><br />The <b>coils in your fridge</b> may have frozen over and now the air does not move at all so then the<b> ice builds up</b> and can <b>freeze parts of the fridge side</b>.<br /><br />The <b>thermostat has gone bad </b>and so now the <b>compressor runs continually.</b> This will not be noticed readily on the<b> freezer side</b> but will show up quickly on the fridge side.<br /><br />Many<b> newer model refrigerators</b> use an <b>electronic sensor</b> or <b>thermistor</b> to read the temperature and supply the info for the <b>circuit board</b> and often a <b>digital readout</b>.<br /><br />So, here is how I would go about <b>troubleshooting</b> this problem.<br /><br /><b>Check the coils for ice</b>, defrost the coils with a <b>heat gun </b>or <b>hairdryer</b>, then check for the reason why they iced over. <b>Defrost control</b> or <b>defrost timer</b> bad? <b>Evaporator fan</b> bad?<br /><br />Check the<b> damper door</b> to see if it is stuck in the <b>open position</b>. If it is then <b>check the motor</b> and the <b>linkage.</b><br /><br />Check to see if the<b> refrigeration unit</b> will shut down if the <b>thermostat</b> or digital setting is turned up to a<b> higher temperature.</b> If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or <b>control board</b>.<br /><br />Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of<b> adjustment in the thermostat</b> or <b>setting of the temperature</b> will not <b>solve your problem very simply.</b>
on Dec 09, 2010 | Refrigerators
Nt side by side fridge freezer not freezing
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
May 22, 2012 | Hotpoint Refrigerators
My refrigerator freezes everthing in one day
When the refrigerator side is getting too cold or freezes, this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Regards.
May 13, 2011 | Dometic Refrigerators
Fridge wires cut
The answer could well be Yes. Ideally you should reoplace the harness anyway. The fridge controls and air valve shutter (see below) will also be wired via the harness.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing
Nov 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
Fridge side began freezing everything then the fan
Generally speaking, sounds like you may have the frozen condensor problem that is so common
because of the design flaw in the Samsung products.
Turn it off, empty the freezer.
Study the back and look for formed ice around the seams.
So it got too cold, and now it is still too cold, or not cold enough ?
May 08, 2009 | Samsung RS2556 Side by Side Refrigerator
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Feb 06, 2008 | Samsung RS2556 Side by Side Refrigerator
Freezer side wont freeze
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting from the condenser has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 14, 2007 | Samsung Refrigerators
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
