Polk audio powered subwoofer model psw 3038 online manual
renosean
  • 492 Answers
SOURCE: No Signal on sub preout on my Onkyo TX-SR703 AVR
Well the next step would be to make sure that all the settings are set to subwoofer yes, and set your crossover as well.  The amp usually has a crossover which tells the microprocessor which frequencys to send to the sub.
Posted on Jan 06, 2009
  • 40 Answers
SOURCE: Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Posted on Mar 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: My subwoofer output is not
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Posted on Feb 11, 2011
dunnbiker
  • 8546 Answers
SOURCE: Yamaha Rx-V367 Subwoofer not working,
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
Posted on May 08, 2011
electrepairu
  • 195 Answers
SOURCE: psw110 polk subwoofer, making a thumping noise, even if you unplug it from the subwoofer not the power source
Have you tried resetting the unit to factory settings?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Posted on Jan 07, 2017
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual http://www.polkaudio.com/Media/POLK/Product%20Manuals/PSW110_125_MN.pdf
There is some discussion here http://forum.polkaudio.com/discussion/77264/psw125-blown-fuse
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
Aug 28, 2014 | Polk Audio Psw 300-watt 12" Powered...
Which amplifier plate can use for Polk Audio PSW 1000
call parts express tell them your problem and they do have a plate amplifier that will work actually it's a better amp with more power.
Jun 14, 2012 | Polk Audio PSW1000 Subwoofer
Good Luck!
Mar 26, 2010 | Polk Audio PSW10 Subwoofer
My Polk PSW 303 subwoofer emits a hum when plugged in and powered off. When the unit is turned on the hum gets louder. At this point the unit is useless. Does anyone know what could be causing this?
Hiya sounds alot like there is a power supply issue with the unit that will require repair for it to be doing off or on. Probably wont be to expensive, request a quote first to make sure viable.
Best of luck
Jul 16, 2009 | Polk Audio PSW-303 Subwoofer
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
PSW 10 Not working
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Sep 06, 2008 | Polk Audio PSW10 Subwoofer
122 people viewed this question
 Grubhead
Grubhead
