Question about HP OfficeJet Pro K8600 Printer
Problem: My HP Officejet Pro K8600 is printing alternating bands of solid and distorted grainy horizonal strips approx. 2 1/2" wide 1) I'm printing full color (8x10, 11x14 & 13x19) 2) I'm printing (any color) 3) I have installed new cartridges 4) I have cleaned and calibrated the printer (4 times) I'm still getting the banding what could be the problem? the printer is 2 yrs. old thanks, Ron
  • HP Master
  • 10,045 Answers
Delete the printer driver completely before re installing it.
Posted on Jul 29, 2017
SOURCE: copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Posted on Jul 25, 2007
  • 15 Answers
SOURCE: ink "banding" on hp laserjet 2600n
Viscosity of the ink is likely your problem. Sure the inks are not leaking at the same time, but that is likely because the different colors use different tints which can be slightly thicker or thinner. Many printer manufacturers (HP most notably) makes many patents on their ink, and not solely on the colors, but also the viscosity. The ink jets could slowly be leaking and might need to be replaced, finding these parts yourself might be easy, but replacing them is not.
I'm going to assume you've replaced the blue and suggest you remove the roller and clean it with glass cleaner. You may find it EXTREMELY difficult to remove the roller, so I would probably find a printer repair/ sales shop. Usually these places are not easy to find, so you'll probably want to find an office equipment sales business. These are the companies that usually sell the larger copier/fax/printers for large offices, or you could call HP and ask where a certified HP printer technician is in your area. I will tell you though, the cheaper ink may have just caught up to, having a copier technician repair this printer could cost quite a lot, but doing the job yourself, could be disastrous. The amount of small screws, easy to break plastic tabs, and interesting clips, etc make the job nearly impossible for a novice.
Good luck -Skyler
Posted on Mar 19, 2009
  • 21 Answers
SOURCE: HP 6310 printer says HP 95 tricolor is empty.
It sounds like you need to replace the cartridge with a new one. The electronics may have went out. We see this usually during the winter months when the static electricity in the air is high and we shock the cartridge. I would also NOT recommend cleaning the head/jets of the cartridge with alcohol. The electronics are fine to clean with alcohol both inside the printer and on the c artridge, but the head will dry out. We recommend taking a damp warm wet paper towel, placing it on a protected surface, and placing the head of the cartridge on the paper towel until you see some ink appear. Then put it back in your printer and let the printer clean off the bottom. If the printer is not cleaning off the bottom of the cartridge, the printer cartridge wiper on the carriage may be broken or stuck.
Posted on May 26, 2009
  • 685 Answers
SOURCE: My HP Officejet Pro K8600
Have you tried all these steps?
Posted on Oct 21, 2010
  • 169 Answers
SOURCE: in hp officejet pro k5400
Try Cleaning the Cartridges manually and automatically.
For the cartridge clean it with a damp lint free cloth and also for the printheads wher eyour gonna be inserting the cartridges.
Follow these steps do do the automatic aligning and cleaning:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
For Cleaning the Printheads, Instead of choosing Align Printer choose Clean Printheads.
I hope this helped.
Try Printing Again. I hope I was able to solve your problem. :)
Posted on Feb 08, 2011
Printing envelopes it prints crooked
Printing envelopes
Mar 19, 2014 | HP OfficeJet Pro K8600 Printer
Hp officejet pro k8600 - wrong print scale
I found the answer in another post that didn't come up with my initial search. In case someone else needs to know, just go into your printer properties, the advanced tab, click the print processor button
Mar 22, 2013 | HP OfficeJet Pro K8600 Printer
I have an HP Officejet Pro K8600 printer and my running programme is Lynux Mint and i cant get the drivers to down load
To Download:
1 Go to 2 Click on Support and Drivers 3 Enter your product name or number, in this case just type in HP Officejet Pro K8600 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
Feb 08, 2011 | HP Office Equipment & Supplies
I have a HP 7590 printer and it sometimes skips line or some of the lines are faded when printing black .
Perform the following steps to reduce or eliminate faded or grainy lines:
  1. Print at a higher quality setting.
  2. Verify that the paper you are printing on will lay flat. Paper that is not laying flat can cause banding when the paper transitions over the rollers or cause the print cartridges to scrape across the surface of the page. Check the top sheet of paper by removing it from the all-in-one and placing it on a flat surface. If the paper does not lie flat, bend it in the opposite direction to straighten it. Figure 3: Faded or grainy bands in print caused by paper that is not flatc00178858.gif 1 - Faded or grainy bands due to roller transition with paper that is not flat. 2 - Faded or grainy bands due to print cartridge scrape on paper that is not flat
Jan 06, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
HP OfficeJetPro K8600 is printing blank lines on the
needs cartridge? or could try cleaning the heads.
Dec 04, 2009 | HP OfficeJet Pro K8600 Printer
HP OfficeJet Pro K8600 Printer Logo
74 people viewed this question
Ben Johnson
