Question about Lexmark OfficeCenter X3350 All-in-One Printer
How to clean rollers on a lexmark 3350 - Lexmark OfficeCenter X3350 All-in-One Printer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached.
Next, try this printer self-test by following the steps given below:
1. Turn off power.
2. Press and hold the "Black Copy" and the "Power" buttons at the same time. Continue holding then until the screen displays "Mfg Menus Enabled."
3. Press the "Menu"(--->) button 2 times.
4. Screen will read "LCD Button Test," press "(-)" button 2 times.
5. Screen will read "Single Test Page," press the "Menu" button once.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
Tech Suppot
Jeeth
Posted on Sep 15, 2010
I am getting dirty copies. How do I clean rollers?
Here's an article in the Lexmark website on How to Check the Paper Tray Feed Rollers on a Lexmark T640, T642, or T644 Printer. Just click on this link: http://bit.ly/b71goj. Follow the instructions carefully. Hope this helps.
Jun 24, 2010 | Lexmark T644 Laser Printer
Lexmark X5490 paper will not feed rollers seem to slip. will work if you help the paper into the printer.
Sounds like the feed rollers are dirty. Use a mild detergent or soapy water and a clean cloth and clean the rubber rollers that turn to feed in the paper.
Do not use alcohol this could dry out and shorten the life of the rollers.
May 18, 2010 | Lexmark X5470 All-In-One InkJet Printer
LexMark 3350 Printer often stops printing in mid multi-page
If printing is stopping in the middle its not the Problem with the driver
Check the Spooling Properties
Checked Printing Test Page
Jan 06, 2010 | Lexmark X3350 All-In-One InkJet Printer
I was given a new lexmark 3350 all in one printer from a friend. She lost the cables and installation disc. Can you help me by giving the the size cable I need and how I can install it to my (pc windows...
The cable that you need is a standard male to male USB A to USB B cable. You can find the support page for your printer HERE. You should be able to download the driver from the link at the top there.
Mar 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
Lexmark 3350-Vista-Prints but Won't Scan
Is this the driver you downloaded. If so , sounds like a Lexmark software or driver problem. I am a little confused as the heading on you question says x1270 but the bold type says 3350?
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Dec 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x 3350 all-in-one
I picked up a used Lexmark 3500 with the same problem. Had requested help fixing.
Tried to feed more paper through - still pulling hard on the right side. Tried to feed several pieces of paper - one at a time, getting them jammed then pulling them back out. Finally one got jammed way down in there - yanked it back out. Open the top(as to load ink cartridges) Saw a tiny piece of paper sticking out between the plastic rollers, got a small crochet hook (tweezers would have worked), grabbed a hold of it and pulled it out enough to get a good hold of it, then pulled it out. There had been a shread of paper jammed in the roller area. 3" long by from 1/4" to 1 1/2" wide.
My problem was the chunk of paper stuck in the roller mechanism where you could not see it or get to it, until it was partially forced out.
Hope this helps someone else!
Oct 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 3350
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X2350
Jul 16, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X3350 printer
Go to Lexmark.com website and see if there are drivers for them.
Jun 13, 2008 | Lexmark X2350 All-In-One InkJet Printer
Printer not feeding paper
This sounds like a classic case of dirty or worn-out roller. Try unplugging the printer from the power outlet. Locate the roller (or rollers) and cleaning the rollers with a damp, lint-free cloth. Rotate the roller to get all sides cleaned. If this does not help you might be able to by a maintenance kit from Lexmark.
May 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark OfficeCenter X3350 All-in-One Printer Logo
222 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
