Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool DU1100XTP vlean light blinking
As in the subject, my washer is blinking clean. Nothing works exsept drain. I heard there is a code to push in to the pannel to reset it. Can you help? Please email me at acethakr@yahoo.com (Whirlpool DU1100XTP)
THANK YOU!!
  • tracyvo2005 Oct 24, 2008
    I have DU 1100XTPB ( quiet partner II ) .The vlean light blinking . I tried to hit heated dry, than hit normal - 3 time . All lights on than , I hit cancel . The dishwasher run like usually, but only fill water and rinse 1 time, no wash no head ???. Please, help me fix this problem. Thanks
  • Anonymous Mar 13, 2014
    Reset and still has same problem
  • 413 Answers
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Posted on Jun 21, 2008
On my whirlpool dishwasher du1100xtp when i push the start. it starts the drain mode. it will not start anything else. i checked the draining of water and its all good. i cleaned everything out too. ...
Most machines enter a drain mode when initially started. Then it will pause and then open water valve. Could be water got turned off or you have a bad water inlet valve. Do you know how to check voltages or use a multi meter
Feb 01, 2015 | Whirlpool Dishwashers
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
Lights are blinking and nothing happens when you push buttons
Have you tried pushing and releasing the sani rinse button, then the heated dry? go back n forth several times. If that doesn't work try the soak and scour and hi temp wash buttons and re post results
Feb 20, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher clean light is blinking
indicates a problem with dw not heating the water. various causes. dw should be thoroughly checked, if nothing found wrong, reset computer
Jan 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Clean button keeps flashing. it fills up with water and does nothing. it will drain when i hit cancel/drain button
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Sep 03, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Washer will not start
Does the dishwasher plug in under the sink or is it hard-wired? If it plugs in under the sink unplug it and let it stay that way for 5-10 mins and see if that changes anything. If it is hard-wired see if you can figure out which breaker it is on and turn it off for same amount of time. Let me know.
Thx
Jul 31, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Clean light is blinking, have already killed the power, then called to whirlpool and they walked me through resetting it by pushing buttons, however when i attempted to run it after resetting it, it...
you may a a latching issue. d/w not latching properly. How long does it take before the clean light comes on after you reset it. does it fill with water? if so, then your motor may be defective.
May 25, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Will not run
than either replace heater sensor or element.
Give me model number pls
May 03, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool flashes 5d
try pushing pause/cancel twice and try again let me know what happens
Jan 17, 2008 | Whirlpool AWM6120 Front Load Washer
Dishwasher has lights but won't do anything
Jacksonville, did you remove the knock-out for the drain on the disposer? Use a screw driver and punch it out. Let us know if that did the trick..Catriver..post back.
Nov 22, 2006 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
544 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
