Question about Samsung LNT4669 TV
When I adjust my Samsung's settings like contrast brightness etc etc, they always just return to whatever the standard was before I adjust them. and its not just turning the tv on or off, if I switch inputs it will do the same thing. this goes for everything adjustable including the blue light on the front of the tv. if i set it to off, it will turn off. the next time i turn on the tv however, it is back on and will stay on after power is turned off.
  • 1 more comment
  • gre666 Sep 15, 2010
    and what does this mean?
    I recently purchased the Samsung LN-T4669F LCD 1080p 46" 120Hz. That being said, most of my settings will not stay where I set them. I thought at first that it was clearing when I turned the TV off, but I realized last night that it switches back to "Dynamic" (which is with contrast set at 100...) in the picture and changes several other settings in the set up screen. For instance, the "Light Effect" setting turns the LED on or off or on only during stand-by, etc. It always switches back to always on.
    I did notice that when I hit the info button on the remote it reads that the picture mode is in "Shop Mode". Changed this and it still seems to not be working.
    yes it is always connected to a power source, even when not in use.
  • 4,889 Answers
I remember seeing an option of auto adjustment settings in some samsung tvs. Can you please verify if they are turned on?
Posted on Sep 15, 2010
    Guru:
  • 374 Answers
One thing I have to ask, is your Tv remaining connected to a power source all the time?? If you let it get unplugged or if there are times it is loosing power it will reset the saved features that are stored after you set them.
That is the first place to check. Let me know and I will get back to you.
Its good to start with the simple things and workfrom there.
  • Samsung Master
  • 5,138 Answers
Assy board P -Function BN96-06420B
Encompass Parts Distribution 1-800-638-3328
  • ladywinn
    ladywinn Sep 15, 2010
    If the set is still under warranty take it back inexchange for another one! Other wise you might need boards resolder first then see if TV still has that problem.
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Televison & Video
I cant put the right colors to my led toshiba tv,,,, the colors looks so bright. Please help????????
The tv is possibly set on the wrong standard.
Try accessing the menu and selecting a different standard; PAL, PAL 1, 2 or 3, RGB or whatever is used in your geographical area.
Once the right standard for your area is employed the controls for brightness, colour intensity and contrast should respond to adjustment and produce the picture quality you require.
I hope this helps.
Feb 09, 2015 | Televison & Video
Best quality picture
This is likely a simple settings issue.
A lot of people don't realize that backlight settings can affect the picture.
Go to the menu (press menu on your remote)
The menu will show picture options. Just toy with different settings until you find what you want. It may be on a preset setting that doesn't work. If you are in a bright room, you will need to increase brightness and contrast and perhaps backlight.
Usually an unclear picture is due to the contrast, backlight, and brightness settings being too low. You can also increase sharpness.
I suggest a contrast setting of 70, a brightness setting of 60-80, and a backlight setting of above 80.
Good luck.,
Mar 08, 2014 | Hisense 50 Class LED HDTV - 1080p, 1920x...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Want to know how to adjust contrast
Very old set--always adjust so contrast not too high--it should always be lower than brightness---say brightness at 75% and contrast lower--if contrast set too high smearing will occur and picture quality will be affected.
Apr 08, 2012 | Televison & Video
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Can't adjust color, brightness, etc. w/universal remote
Use the MENU on the front panel display of the
TV
Jan 06, 2010 | Televison & Video
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Samsung LNT4669 TV Logo
Henry  Thomas
Henry Thomas
