Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Where can i get a replacement mx-3000 cradle charger base?
2 Suggested Answers
  • 15 Answers
SOURCE: my mx 3000 will not charge. I got a new battery & nowthat is dead
Contact Total Control Remotes - www.totalcontrolremotes.com - They offer diagnostics over the phone and in the least can get you a replacement battery or base in a day or two. Great customer service and many different types of products and services.
Good Luck
Posted on Sep 27, 2009
Phone is displaying "out of range or no power at base." How do I fix that?
There's the charger base cradle that plugs in to the phone jack and power socket on the wall. Make sure both things are connected. The phone handset requires that the charger cradle is plugged in with power and phone signal. Make sure you have done that.
Nov 07, 2014 | Vtech Lands Phones
Battery goes LOW , then power stops This remote is only 2.5 years old
If you haven't replaced it yet then it's normal - the rechargeable battery has aged and must be replaced. Here is one
http://www.amazon.com/Replacement-Battery-MX-3000-Powercard-pc046067-h/dp/B002R96LDC/ref=pd_cp_e_0
Jul 28, 2010 | Universal Remote Control MX-3000 LCD...
Mx3000 does not charge when in cradle. nothing
I agree with ceocass, however if you find that the contacts are clean and you have made certain that the charging cradle is plugged in you may simply need to replace the battery.
Please note that the replacement batteries for the MX3000 Universal Remote Control, p/n's Powercard PC046067-H & PC036067V3 have been discontinued.
TheBatteryStore.com now carries an alternative battery, p/n PL056067V3 which is a 2,100 mAh typical capacity battery that can be used as a replacement.
Please confirm that the connector type is the same as your battery prior to placing your order. We only carry this battery with the Version 3 connector which has a built in pressure release tab.
The link for the product page is: http://www.thebatterystore.com/replacementbatteryforuniversalremotemx-300037v2100mahli-ionpolymerrechargeable.aspx
If you have any questions please contact TheBatteryStore.com at sales@thebatterystore.com.
May 27, 2010 | Universal Remote Control MX-3000 LCD...
My mx 3000 will not charge. I got a new battery & nowthat is dead
Good Luck
Sep 06, 2009 | Universal Remote Control MX-3000 LCD...
Where can I purchase a Lithium battery 046067 for an MX 3000?
Do you favorite search engine and type your model number and then batteries. What I got is www.buy.com
Aug 18, 2009 | Universal Remote Control MX-3000 LCD...
Power Card will not hold charge cannot find replacement
the battery may be faulty or the charger. try a different charger and see what happens. one of them is the problem good luck.
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Logitech MX 5000
By default this comes with rechargeable batteries but just to make sure it isn't a battery/charger problem try using new alkaline batteries. If it works then you may have a problem with the charger. If the problem definitely isn't batteries then the next candidate is transmission of the signal between the cradle and the mouse. Move the base or the mouse to within a few inches of each other. Make sure the mouse is working then start moving the mouse/cradle to its original position or further away till the problem reappears. Chances are you'll find an obstruction or a distance issue. Ordinarily these should transmit at least 3 to 5 feet away, sometimes even further. Over time I have seen a degradation of the range to the point where they have to be fairly close together to work reliably. If its still within the warranty I?d call Logitech for a repair/replacement. Let us know if you have any other questions otherwise thanks in advance for rating this post.
Apr 02, 2007 | Logitech Cordless Desktop MX 5000 Laser
Cordless MX DUO charger
try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
Jan 10, 2007 | Logitech Cordless MX Duo 967300-0403...
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
112 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
