Question about GE Monogram® ZBD6880NSS Stainless Steel Dishwasher
The door won't open - ran and re-ran the wash cycle, and it still won't disengage.
  • 901 Answers
Switch OFF the main power and try. Give a bang by hand on the latch side. It might open. Do not use hammer etc.
If nothing works you have to force open carefully.
Posted on Sep 15, 2010
Door lock on washing machine wont disengage
you could make a bypass switch, which interrupts the power to the door lock I would suggest a push button (press to open), so that it doesn't interrupt normal function(you can't accidentally leave it off), just attach the lead wire that would normally go to the lock mechanism to the button, then attach the return lead from the switch to the original circuit on the locking mechanism. then when you want to open the door (if it sticks again) you just press the button to break the circuit
Feb 01, 2016 | Indesit Washing Machines
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Amana NFW 7200 TW door won't close because lock is engaged
You door lock is bad and needs to be changed. Without the proper model number I can't really give you accurate instructions
Jun 22, 2012 | Amana NFW7300WW Washer
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Can't open door
Make sure the power is on, make sure the machine has finished its cycle, move the dial around to the final cycle and let finish, the door lock should disengage after the cycle is finished, if this doesn't work, make sure all dials are in off position and switch of at the wall and then switch on again. still on luck then there may be a small access hole (usually only big enough for a pen) to disengage the door lock.
Nov 08, 2010 | Danby DWM5500 Front Load Washer
Mold and mildew in door. washed, cleaned, ran
the only thing you can do now is replaced the door boot seal. after replacement usually you have to leave the door open till completely dry or dy it with a towel after each wash
Sep 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Stuck door latch after cleaning
door latch stuck but the door is open and i can't close the door back
Sep 29, 2008 | GE Spectra JBP78 Electric Kitchen Range
Can't Open the Washer Door---Our Clothes are held Hoatage
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Apr 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
GE Monogram® ZBD6880NSS Stainless Steel Dishwasher Logo
153 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
