Question about Bulova Watch
Shorten the band on a Mossimo watch - Bulova Watch
  • 831 Answers
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Posted on Sep 15, 2010
    3 Suggested Answers
    escapement
    • 2334 Answers
    SOURCE: how to shorten the watch band without breaking it
    You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
    First you have to find out what sort of pins or even screws are used to keep links together.
    Examine both bracelet sides and find the side where pin ends have a groove.
    Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
    For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
    Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
    NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
    Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
    After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
    After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
    It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
    Make sure that pin ends are flush with bracelet. If needed- hit few more times.
    Job done!
    If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
    Don't forget to rate, please.
    Posted on Apr 09, 2009
    • 183 Answers
    SOURCE: shorten watch band
    For this you will need a pair of fine tweezers, a small flat blade screw driver and a lot of patience.
    Determine how many links you need to take out by pinching the band while it is on the wrist. Once you know how many you are ready to remove the links.
    spread the band and you will see that the very end of the links is tabbed. Be careful and fold down the end of the link with your small screw driver. Be careful not to bend anything. You will then need to turn the band over and bend down the tab of the link on the opposite side but right beside the first tab you bent down. Now you will see how the band is held together. If you look into the two tabs you just bent down you will see a small peice of metal connecting the two links. This is a staple. Pull the staple out with your tweezers.
    Now go to the exact opposite side and perform the same task. The band should now be apart where you remove the staples from each side.
    Now count down the number of links you want to remove and perform the task again.
    *Remember that you must do it the exact same way on each side or the band will not go back together.
    Once you have the correct number of links out the band will go back together the same way you took it apart.
    When folding down the tabs be sure to use gentle even pressure so you dont over bend them and keep the band from moving freely. I usually find it easiest to use the fla part of the screw driver in a gentle pressing motion.
    Remember that this take watch makers and technician a lot of practice. Be patient. If you arent patient or good with very small parts, pop into your local jewlery store for help.
    Posted on Sep 17, 2009
    How do I shorten ******** my Tag Heuer Formula 1 watch?
    Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
    Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Mossimo watch instructions
    If it isn't working, return it.
    Nov 01, 2013 | Watches
    How do I shorten my Ice watch strap?
    mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
    Jul 17, 2010 | Watches
    Men's Mossimo Chronograph watch has 1 stem to change the time and has a day and a month circle. How do you set them?
    if its the gunmetal one with the rubber wrist band you cant i just took it appart and there is noting to turn the analog day date or...what ever the other one is sapose to be there actualy just fake and are there to make the watch look fancy ..... f-n lame as sh!t
    Dec 13, 2009 | Watches
    Mossimo alarm
    While in (digital) Clock mode (NOT in alarm setting mode!!!), push the bottom-right button and then the top-right, to toggle alarm on & off.
    Jan 29, 2009 | Bulova Men's Watch
    Shorten band
    Hi Go to www.skagen.com top r/h search box - input your model number click on go,
    On the new page at bottom/left, click on customer service.
    On new page left side click on instructions.
    On new page you will find instuctions on how to shorten/lengthen bracelet.
    Oct 24, 2008 | Skagen 107SSSBD Wrist Watch
    Getting analog part of Mossimo watch to start
    FIXED!!!
    As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
    Have the watch serviced to change the second battery and VOILA!!!!
    Enjoy!
    Mivales.
    Made in Costa Rica!!
    Sep 01, 2008 | Watches
    Need to shorten a band
    you better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
    Jun 24, 2008 | gossip Watches
    Mossimo watch
    Try this:
    http://www.webjeweller.com/jewellery/removelinks.shtml
    For my band, the trick is to use a 1mm jewler's screwdriver and push against the pin in the link. The pins exit in the direction of the arrow on the link (and go back in opposite direction).
    Pushing on the pin can be tricky. If you slip you'll stab your finger with the screwdriver. It takes a little more pressure than you think, but once the pin moves it comes out easily.
    Jun 21, 2008 | Watches
    Bulova Watch Logo
    3,276 people viewed this question
    Top Bulova Watches Experts
    Geoff
    Ansel Alberto
    Ansel Alberto
    Are you a Bulova Watch Expert? Answer questions, earn points and help others
