Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How do I set the timing on a Lawn Boy 10685 lawn mower? She was running just fine, then quit. I've cleaned out carb, replaced spark plug and replaced ignition coil. Still want start - no fire.
SOURCE: 2 cycle oil to gas ratio for Lawn Boy mover Model 10324
32 parts gasoline : 1 part oil
Posted on May 06, 2009
  • 89 Answers
SOURCE: what locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Posted on Nov 04, 2009
  • 420 Answers
SOURCE: lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
Posted on Jun 01, 2010
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
  • 885 Answers
SOURCE: can you run your lawn boy mowers without the
Yes you can. The only reason small engines have the primer button/bulb is to get gas to the carburator to make it easier to start it. If your mower starts OK without using the primer bulb you will not harm the mower.
Posted on Apr 14, 2011
Why wont my walk behind mower wont start
take your spark plug out put some gas in the chamber replace plug if it fires and not run it is in fuel delivfry check and see if carb. is gummed up if so clean it if not check for restriction in gsas from tank to carb. one of these is the problem
May 23, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh 13hp overhead valve snowblower engine starts fine than sputters and dies, replaced the carb with new and exact same symptoms, Lots of fuel at the carb.
Make sure the fuel is good. Ethanol laced fuel starts to varnish after 20 days and is no good by 30 days, it also attracts water. Be sure you have good fresh fuel, then try a new spark plug.
Oct 19, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Lawn Boy 10685. Changed the blade and went to start the mower and the pull cord will not pull. I tried spinning the blade by hand with no luck. I took the starter apart and it spins fine. I check...
Remove the spark plug and try pulling the starter again. You may have a fuel leakage into the cylinder and it has caused a hydraulic lock. Check/change the needle and seat in the carb as this leaking is the usual cause if this type of problem. Good luck and please rate this solution.
May 22, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn boy 2 cycle mower won't start
May 29, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Mower will not start and i dont know wut to do need help the primer button is broke and i replaced the spark plug
take the carb out remove the folat bowl, float, needle and seat. Blast all the small passages out with compressed air.
Apr 24, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
75 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
