Question about Miller Welding Tools
We use Miller Auto Axcess 450 integrated with ABB robot. The problem is the Robot suddenly stop welding and the Miller Welding set indicate 'Over Current'.But after off and on,the robot works for a while and then goes back to the same problem mentioned above. From the manual, it stated that we have to press Purge/Jog buttons to clear the error and set the current value lower. Unfortunately we have tried that but no effect.
SOURCE: Trying to weld with Hobart 125 EZ
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Posted on Feb 03, 2009
  • 7 Answers
SOURCE: Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Posted on Feb 04, 2009
  • 27 Answers
SOURCE: Welding current traveling over electrical equipment grounds.
Are you saying that the Ground cable in your extention cables are overheating / melting the insulation
  • 5 Answers
SOURCE: handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Posted on Apr 08, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
My company has a Miller Axcess 450. It was set up for MIG Aluminum. Whoever set it up, before my time, set a password. Now I cannot switch over to stainless. We don't even weld aluminum anymore. We don't...
go to www.millerwelds.com>files>ow
there is a pdf version of the user manual and page 30 shows how to reset the machine
if the link doesn't work for you go google and type in -- password resetting for miller mig welder 450-- and there are plenty of pages and pdf version that may help
Dec 02, 2017 | Miller Welding Tools
Miller 350p wire feeds but dont weld
Remove any paint or rust and make sure your ground clamp has a firm grip on whatever your welding or welding on and a nice clean surface
check all welding leads
Nov 24, 2015 | Miller Welding Tools
What does NET WAIT stand for on my miller axcess 450 and how do I get it to go away/fix it?
So I spent half a day swapping boards from a good 450 axcess from what I found between testing and the manual the net wait stands for network updating. The problem I had is the pc7 board (user interface card ) had a burnt spot on the solder joint for the ground I replaced the pc7 board and this fixed the problem.
May 06, 2014 | Miller Welding Tools
I have a miller sycrowave 250DX i have been tig welding for about 10 years i bought this machine 2nd hand hoping it would work ok when i weld in AC and hq the arc seems like it just wants to stop it...
Did the machine ever work properly? I am assuming you are using a remote for tig welding. If you watch the points, does the HF stay on after the 5 to 10 seconds as you stated. It should stay on as long as you activate the machine. Make sure your Start Mode is in continuous. See page 42. Since there are so many options, check page 34 for help setting the options. If you still cannot get ti to weld properly, contact Miller for service. https://www.millerwelds.com/files/owners-manuals/O363AU_MIL.pdf
Aug 29, 2017 | Miller Electric Manufacturing Electric...
Sir, we are using machine mounted MIG welding torches.Before these torches are working properly, now we got problem i.e, nozzle became red hot, cos of this we had stopped our production. pls suggest me.The...
Ensure that you are using the correct contact tip in the welding gun, if the tip is too short; the cup will fill with splatter and submit excess heat to the cup.
Also, make sure if you are using a name brand gun 'miller, lincoln etc' to use THEIR contact tips, the miller guns use a special tip 'the threads on the tip are mashed into the gun ensuring maximum contact for high amperage welding' if the wrong tip is used, it will overheat and jam the wire.
Another thing to remember is to check the amperage rating on the actual gun itself; you may have a 150 amp maximum gun on a 300 amp welding unit.
Good luck
Feb 09, 2011 | Lenox 21172 Welding Torch
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
Ground lead arcs when I connect, and auto idle kicks up
Hi
what are you connecting the ground lead to?
Is the welding machine phisicaly in contact to what you are welding ?
Can you electrically insulate the welding machine from everything, say stand it on a sheet of timber?
Regards
Rob
Feb 07, 2009 | Miller Welding Tools
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Welding Tools Logo
342 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
