Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Trouble shoot ice maker - Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
    President:
  • 1,218 Answers
Good day,
If the ice maker isn't producing. Follow this guide. It should solve your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Sep 15, 2010
  • 151 Answers
SOURCE: Ice Maker just stop making Ice. The water still
Check the bar that's used to sense when the tray is full, is in down position.
Posted on May 14, 2009
  • 17 Answers
SOURCE: Ice maker does not work at all.
On these machines their is a thermostat that tells the ice maker that it is cool enough to turn on rotate and turn the waterflow on.Their are 2 different types of machines.Some machines pull cool air from the top of the machine downward in between the back of the machine and the wall and then out the bottom of the machine or even worse some machines pull cool air from the bottom of the machine upward in between the wall and the back of the machine and then out the top of the machine.The thermostate is either located on the bottom of the machine or on the back of the machine.You should clean all the dust bunnys and debrie from the back and bottom of the machine (make it look new).This adds to the airflow also sometimes when installing the machine people pull off the cardboard from the back of the machine this is usually at the bottom of the machine.If this has happened just cover it with some cardboard and some duck tape.You should be able to put a 4x4 inbetween the back of the machine and the wall.Do not stack or limit the stack of stuff on the top of the machine.The freezer should be in between 32 and 35 degrees this maters even if it is off a degree or 2 the machine may not work.It may take a little wile for the machine to cool down enough for the ice maker to kick on.A simple thermamitor would be nice for testing the temp.This is only one option and it may work or it may not but hey it is cheep
Posted on Jul 27, 2009
aasc
  • 1606 Answers
SOURCE: frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Posted on Oct 02, 2009
  • 112 Answers
SOURCE: shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Posted on Oct 29, 2009
pioner
  • 10 Answers
SOURCE: Ice maker is not working. I have checked all the
Electric appliances are always at a risk of breakdown. there might be several reasons for this problem. I suggest to call a Ice Maker Repair expert near you as he can better detect the problem as compared to you.
Posted on Mar 25, 2011
The icemaker isn't making ice. any trouble shooting suggestions?
Check freezer temp - has to be at least 10 degrees or less for ice maker to work. Check out ice maker cam motor, water solenoid, tray heater, arm that monitors ice levels, etc.
Apr 08, 2016 | Refrigerators
Ice maker wont work
The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
Jan 14, 2014 | Samsung RS267TDBP Side by Side...
How do I start the cycle on this ice2o ice maker? i have ice in the tray but the ice never dumps in the bin.
Go to page 19 in the Whirlpool Ice Maker Trouble Shooting Service Manual The manual should explain more than you will need on your Maytag/Whirlpool brand refrigerators. If you have questions please let me know, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
Looking to trouble shoot an ice maker on my fridge that has gone south on me
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Kenmore Refrigerators
I have a kitchen aid fridge and my ice maker stop producing ice i tried turning off the ice maker switch for 30 seconds and on again waited 24 hours and nothing what else can i do to resolve this issue.
You can use this ice maker manual to trouble shoot and repair your ice maker.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f6bad9d0e44bf81d852573e900695d73/$FILE/8178689%20%28Icemaker%29.pdf
Jul 09, 2010 | Refrigerators
Ice maker stopped making ice, it just stopped. There is nothing blocking the outlet, no debris. The water dispenser still works fine but the ice maker is not working. I have a whirlpool 2665 refrigerator....
your ice maker unit is gone bad if you have warenty get them to replace the ice maker if not you need to do it :(
its coast +- 120$ :(
911service today . com
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
