Question about Kenwood KDC-217 CD Player
Hey i have a kenwood kdc-217 and it is not working. it has power, i can hear it turn or something when i plug it in. no lights come on when it is plugged in and no controls work. there is also no sound so somthing is wrong with it i just dont know what
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Are you getting power to both the yellow and red wires?????
Posted on Sep 15, 2010
  • 1 more comment
  • kettwich08 Sep 16, 2010
    yes i checked all wires, power to everything but its just not working
  • kenw392
    kenw392 Sep 16, 2010
    did you check the fuse in the back of the deck?
  • kettwich08 Sep 23, 2010
    yes fuse is good even replaced it and does not work
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
I just bought a used car with a kenwood kdc-mp142. The radio doesn't work and has protect across the screen. Help me to find out how to unlock it or use the radio....thanks
Hey i had the same problem and i've just solved it you just gotta reset the radio the button it´s between the FF button and the 1 button gotta push it with one clip or something like that
Sep 18, 2010 | Kenwood KDC-MP142 Car CD/ MP3 Player
How do i set the rca settings for my kenwood kdc-217
Theres no way to change the rca settings. More than likely they put out 2 volts which is more common. Some newer more expensive models put out 4. What size remote wire you using? Try using a bigger (smaller #) gauge wire. That will give it a boost if your using the one that came with an amp kit. What kind of speakers? What kind of amp? If amp is mutli channel and only one sub then you will need to bridge the amp. Try different combos of + and - to see which gives the best. Also make sure everything is turned up on the amp and set to low pass frequency.
Jun 22, 2010 | Kenwood KDC-217 CD Player
Which wire is my amp power wire on a kenwood kdc-x617
hey mate,
You will need to run independent power and ground wires for the amp, then run your RCA leads from your headunit to your amp, the trigger wire to turn your amp on and off with the headunit is the pink and black wire in the kenwood wiring harness...
Hope this helps
Brad:)
Sep 22, 2009 | Kenwood KDC-X617 CD Player
Need un lock code for a KDC-MP528 kenwood cd
Hey to reset the code on a Kenwood deck try this: Hit Disp 1 one second after V up spell KCar w/track up button it should work.
Sep 19, 2009 | Kenwood KDC-MP528 CD Player
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Oct 11, 2008 | Kenwood KDC-MP228 CD Player
New KDC-135 won't turn on...
Hey Bandad, you will need 12 volts at the backup wire also. Try that and see how you go.
robotek
Apr 07, 2008 | Kenwood KDC-135 CD Player
No sound
it sounds like you have a short on two of your speaker wires just connecy front speakers and try then rear then left then right to prove which one or ones
chris
Oct 29, 2007 | Kenwood KDC-217 CD Player
Kenwood KDC-217 CD Player Logo
100 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
