Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer turns on for a second and then shuts off
  • 100 Answers
My printer would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Posted on Mar 28, 2011
I have replaced waste toner unit with new one on a WC 5050 and still shows the error message as full so unable to print
Reset to Default settings, if that does not work, shut down printer, unplug power from printer, shut down computer unplug power from computer, wait 20 seconds, plug power in to computer plug power in to printer, wait 5 seconds, boot computer, turn on printer.
NOTE: This should solve most problems with printers.
If still not working you have a faulty Toner unit.
Sep 21, 2013 | OKI C9600hdn Laser Printer
Canon MP495 turn on/shuts off
Your printer need service because you had an internal part that is causing the problem..
Jul 15, 2013 | Office Equipment & Supplies
Can not print envelop with Dell 1110 Laser printer.
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
restart the computer:
  1. Click Start and then Shut Down.
  2. Click Restart.
    The computer restarts.
Nov 02, 2010 | Dell 1100 Laser Printer
Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Apr 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
The off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Pacemark 3410 - printer shuts off after 30 seconds
Good chance the power supply is burned out. Located in the rear bottom of unit. You must remove the whole machine from case to get to it. Costs about $200.00 at any shop.
Aug 04, 2009 | OKI Pacemark 3410 Matrix Printer
E42
Try to do a reset of the printer
Press and hold the on/off button for 1 second
If printer does not shut off, unplug printer
Wait 20 seconds
Press on/off button again to turn on printer
It might have been a scan problem
Mar 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark x6170 random shut off while printing
I think the power saving mode is on your printer ?try setting to off mode or 2 hrs mode...
Mar 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
