Question about Kenmore Elite 45986 Front Load Washer
I get a DL flashing and now my dorr can't shut
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Have been using this HP LaserJet4Plus for a long time now with nary a problem. Just today, after it printed a few pages, it came up with the error ME (flashing) FEED DL. Now when I try to print, one page...
ME FEED DL is displayed when there is a request for a manually fed envelope.
The DL is the envelope size that it is looking for.
Put the aforementioned envelope in tray 1 and press ONLINE to print.
By the way, a DL envelope is 110 × 220mm. It is used on a 220V printer.
If you don't have one, cut a piece of paper that size and humor the printer by putting it in tray 1. Let it print and see if that gets rid of your problem. If not since you already tried Cold Reset, try NVRAM reset. Hold down JOB CANCEL while power cycling the printer.
Remember, this will set page count to zero and all other SERVICE MODE settings to defaults. But it will set tray 1 to LETTER.
Mar 25, 2011 | HP LaserJet 4 plus Printer
Rear door handle broke door won't open how can open it with it being shut
Theres no easy way, best way is to take the door trim off and try and get to the back side of the lock to open the door. this is not alwys easy with the dorr being shut so just see if you can get your hand in and push the lock over.
Jan 15, 2010 | 2002 Honda Accord
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Can *ist DL do High-Speed/Wireless Flash?
According to the manual (page 153), the DL DOES support P-TTL flash, with the built-in or external flash, but only supports high-speed flash with an external flash. What I'm wondering is, what is high-speed sync flash useful for? The only thing I can think of is fill-flash outdoors.
Kenmore Elite 45986 Front Load Washer Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
