Question about LG Computers & Internet
My lg x110 just stopped work and will now not boot up
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
  • 1 more comment
  • seyal30
    seyal30 Aug 07, 2014
    sum's it all up but for a pro
  • seyal30
    tried removing keyboard with no luck !!! still didnt work
  • seyal30
    check when you turn on the laptup the HD led fleckers randomly if it does meen the laptop is working butthe problem is in the screen
Have the same problem checked every think by the check list above
the last two part would be better to buy new simple laptop
more accurete description of the problem...
1) when I turn on the kaptop the power button lites up and the power led turns orange and the barty stayes lit orange but the wifi led turns on also orange
2) can here the cpu fan starts for a couple of seconds then stops
I checked all inter parts seems ok ... maybe circutes are fried dont know...
.... I tried disconecting the small iner battry for the bios but still no use
I need to check if the charger voltage is ok ...
one more thing ... thsi is importang i fixed some laptops with this state by changing the keyboard somtimes the customer spil liquids wich couses the system to shorten simple check just disconect the keyboard and try booting..
havent tried that yet :) I try and give you an answer... with my next post...
Posted on Aug 07, 2014
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: LG Netbook x110. The screen doesnt work
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 28, 2009
My lg x110 has no wireless set up in order to connect to a wireless router
What do you mean has no wireless setup? It has no built in wireless>
Oct 18, 2013 | LG X110 series (610074350750)
RESTART LG COMPUTER
I have the same problem, but no solution. have you tried a new power cord?
Nov 01, 2012 | LG X110 series (610074350750)
Crack bios password on my lg x110 - forgot bios password - can not get factory reset - help please
A password is required for access to the BIOS and I do not know the password. I have had this problem for quite some time now but luckily I've managed to get access to the BIOS now. I used lots of different programs to crack the password but I failed in vain. I removed the little battery that sat on the motherboard but nothing happened, I ran Hirens bootcd 15.1 and it did not help either. Eventually I got hold of a new system BIOS for my LG X110 and then flashed my BIOS. No password is needed now :) Download LG Notebook (X110/XD110) System BIOS here -> http://download.notebook-driver.com/driver/LG/X110/BIOS_Setup_X110.zip and run the program. That should solve your problem, because it did for me :)
Jun 19, 2012 | LG Computers & Internet
Where can i download the recovery software for my LG x110
Thanks for visiting FixYa!
If you need to download the recovery software for a LG x110, click on this link: http://thefilestreasury.com/?search=lg+x110+recovery+cd&wmid=143&hl=US
Feb 17, 2011 | LG Cell Phones
I have an LG X110 notebook and I want to restore it to its factory settings before I sell it. Anyone help?
The best answer to your question is right here!
Hope this takes care of everything for you
http://www.user-guides.co.uk/cddownload/LG/LGX110/LG-X110-XP-Driver-CD-Recovery-Restore-Disk-243765.html
Jan 16, 2010 | Acer Aspire One PC Notebook
Cursor frozen, won't respond to touchpad LG X110
Press fn+f9, this is a mode for locking and unlockig touchpad
Jun 04, 2009 | Computers & Internet
MBR record
boot from an original XP cd, 1st option select "r" for repair. Select OS... Normally "1", then type in your administrator password, normally blank. when the command prompt is ready, type in "fixmbr" follow prompts and then type "exit" to restart.
See if that helps
Apr 22, 2009 | Computers & Internet
Danish keyboard setup for LG x110
just setup the language from the control panel /regional and languages...select languages add ...and select danish ...you migh leave english on and ...select them as needed..cause sometimes its issual ...if not remove english ...by select it ..and delete
Mar 12, 2009 | LG LW20-EV Notebook
I just purchased a display model notebook lg x110. i'd like to do a system restore and wip all the date off - can you help me?
If you reinstall windows, its probably best to format the harddisk. To get started, insert the window cd/dvd into your drive and restart the laptop. While it restarts, tap the "delete" button repeatedly in order to enter bios. there you can set the dvd-drive as the boot-device. Look for a menu called boot or boot-order. exit the bios and save the settings.
the laptop will then restart and boot from the windows cd. The insallation process will start and you will just have to follow the directions =)
hope this was what you were looking for.
Jan 30, 2009 | Computers & Internet
Computers & Internet Logo
918 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
