Question about Brother MFC 240C All-In-One InkJet Printer
There's a little piece of paper stuck, and I can see it from the back
    Sergeant:
    Champion:
  • 251 Answers
Get it out of there!
Posted on Sep 15, 2010
Printer keeps saying there is a paperjam but theres no paper in it
Sometimes when a paper gets stuck in the printer after removing it a little piece could be stuck in the sensor of the printer. Try opening the top cover of the printer as if you were going to remove the cartridges and check for any little pieces of paper or for anything that could be causing a paper jam. If you do not find anything it could mean a bad sensor or the printer not function properly if you want you can reset the printer here are the steps on how to do that. http://www.bit.ly/aAwUQh
Feb 26, 2010 | Lexmark X5470 All-In-One InkJet Printer
Fellowes 3011001 shredder stopped shredding. tried to remove shredded pieces but could not.
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Nov 15, 2009 | Fellowes 3011001 Shredder
It prints one page at a time and to print next page i have to open the trade and close it back again it look like it pick up the page but does not push it thru
There is a little round plastic gear like piece that pushes the paper up and thru the printer. Sometimes, when there is a paper jam, and the paper is stuck, this little piece can be pulled out or broken, by accident. If the part can be found, then you can glue it back in place, although, this doesn't last too long. I have had to replace many of my printers because of this part and haven't yet figured a way to fix it permanently, because I am dealing with a little plastic cheap part.
Sep 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper got stuck in Konica Milolta magicolor 2400w
I had the same problem and this worked, although it is not the answer to your question:
Take a standard manila file folder and cut it to the basic shape of a standard piece of paper. When you lift the top cover on the under side you will see a diagram on how to pull the paper out in the case of a paper jam. Feed you file folder up from the bottom and you will ~ with a little work, more than likely be able to clear the jam.
Feb 20, 2009 | Konica Minolta magicolor 2400 Laser...
HL-5140 paper jam
Perhaps look along the paper path for the little bit of paper that maybe stuck along the path somewhere. I had this problem and it was just a little piece of the corner of a page wedged in the back of the toner tray.
Dec 30, 2008 | Brother HL 5140 Laser Printer
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
Paper jam, open back cover, then remove paper jam
Ther is some tiny little paper piece left in the machine! You will find it at the left hand side near the gear wheels ;-)
Jun 13, 2008 | Brother MFC-5460CN All-In-One InkJet...
PAPER JAM
Some times there is a little piece of paper stuck in there.
I don't know what make/model of printer you have but this ussually works.
Unplug the printer, switch the paper lever to the envelope setting, take a strip (about an inch wide should work) of card stock and run it up (the opposite direction that the paper runs) through the paper path, sliding it back and forth, it should dislodge anything that is stuck in there.
It is sort of like flossing the printer, but don't be too rough with it, you don't want any of those little parts to come off.
When you are done plug it back in and see if it works.
Jan 09, 2008 | Computers & Internet
Paper Jam
Try putting a piece of tape or something sticky on the eraser end of a pencil and try to work out the paper. Sometimes, you can use needle nose pliers or other long nose pliers to grab the paper and pull it out.
Dec 13, 2007 | HP Officejet Pro L7680 All-In-One Printer
No paper fed
I'm guessing that little piece of plastic has something to do with the paper sensor.  You may want to open that section and set it back the way it was.
Oct 27, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
14 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
