Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Squeak as drum rotates not the agitator in the middle? Bearing or motor?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Sep 15, 2010
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Dryer is squeaking bad
its either the belt slipping .... the motor ....... or the main drum bearing you can take the belt loose and spin the drum and listen for the squeak then spin the motor and listen that should tell you which is causing the squeak
Mar 26, 2012 | Washing Machines
My dryer squeaks
First you should try to determine what the squeak is related to, does it happen every time the drum rotates or more frequently. This will give you some idea of where to look. You should disconnect it , take off the top and get someone to rotate the drum by hand while you listen. Moving parts are dangerous don't put fingers in. Commonly the outer drum bearing or belt idler need lubrication. Don't lubricate the belt. More details if you provide more clues.
Jan 13, 2011 | Frigidaire Dryers
My hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Oct 24, 2009 | Hotpoint NVLR333EE Dryer
My dryer squeaks when it's on? It's a G E. How do I get inside to look around?
Check Idler pulley and rear drum bearing first. One of those is likely to cause squeaking when it fails. Idler pulley can be checked by removing lower rear panel. It's located right next to Motor.
Rear drum bearing is replaced by raising top and removing front and drum. Often just the bearing sleeve needs replacing unless the support shaft or housing is deformed.
Aug 21, 2009 | GE Dryers
Dryer squeekes on and off
Hello.
Intermittent squeaking usually arises from drum rollers, a bearing at the back of the tub or the pulley for the belt. Locate where the squeak is coming from the loudest and you can narrow down the cause.
Loud in the back middle: Drum bearing kit
Loud in the back bottom: Drum rollers.
Loud in the top front: Drum glides
Lound in the bottom front: Belt pulley.
Jul 21, 2009 | Dryers
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
Dryer squeaks when I use it
Hi, I had a squeaky Zanussi TC482W. Had it apart (easy to do) by taking the back off. Cleaned out fluff from around the drum and greased the rear bearing. Reduced the amount of squeak but still there. Took it apart again and almost by accident discovered that the bearing that the shaft at the rear of the drum sits in is actually in two parts. The actual bearing is shaped like the olive you get in plumbing compression joints and should be free to swivvle in the housing to allow some flexibility in drum rotation. A squirt of WD40 and some gentle wiggling with a piece of dowel soon had it free and its now flexible enough to take up the slight movement of the drum about its axis . Problem solved.
Aug 13, 2008 | Dryers
Maytag Mav2755AWW
hi tecate.
This can be a few things, either bearing,transmission, drivebelt or motor.
Start with the drive belt. Take it off and see if the drum when rotated makes the same squeak as befor when you apply a little pressure to the drum.
If it does not do it it can be the tension in the belt. Or the belt is gone HERE are drawings and partslist. You can also obtain the parts here
Jun 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
598 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
