Question about Maytag EPIC MFW9700S Front Load Washer
Maytag washer model #mvw 8700 vqo making nose do not agitate
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
Master_Tech
  • 770 Answers
SOURCE: maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Posted on Jan 27, 2008
  • 96 Answers
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Posted on Mar 13, 2008
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
  • 3741 Answers
SOURCE: my washer wont agitate ?
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Aug 20, 2009
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
May 12, 2009 | Maytag PAV2300 Top Load Washer
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Nov 28, 2007 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
