Question about GPX PDL805 Portable DVD Player
WELL,I CAN"T FIND CHARGER FOR PLAYER SO I DO NOT KNOW FOR SURE WHAT IS GOING ON RIGHT NOW.need a place i n charleston s.c. that may repair or have parts
  • GPX Master
  • 8,457 Answers
Tries websites like Partstore.com,Amazon.com,Ebay.com to buy an original charger or a compatible one.Or might visit Radio Shack might have an original one or a compatible one.
Posted on Sep 15, 2010
I lost the charger, and i can not find, one do you know where i can find a charger?
"Charging the Player
To charge the player, simply connect it to a powered USB port, or external AC adapter. If you choose to use a third party adapter, please ensure that it is 5V and between 350 and 500mA. "
i'm assuming you need a mini usb or micro usb cable? many phones charge using these...you can buy one at tons of stores. just make sure you get the right one. you can charge from your pc (with usb port) or a wall outlet, provided you purchase the correct charger.
(from )
Oct 16, 2013 | Mach Speed T2800 MP3 Player
I am not sure just yet, but I think my sound has gone bye bye. I have had this 53" set for about 7years and it was 2 yrs old when I bought it from Rent-A-Center here in Charleston, SC. Is this something I...
U can go to the menu reset everythings in the audio setting.Unplug,replug an hour later,all the setting it will reset back to factory setting.Ur audio should return to normal.
Apr 05, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Battery will not hold charge
make sure its charging by going in to the options tab, then system, then power options and look at the battery meter and see if its moving left to right while plugged in to the charger.
if its not,
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 06, 2010 | Magellan Maestro 4000 GPS
I need a part number and size for the drum belt for a GE [DDE5300GAL WH] dryer. I also need to know if there is a place you would suggest in finding that belt near Charleston, SC> The dryer is in good...
The part number for the belt is WE12X10014. The characteristics are 87 inches long, by 1/4 inch wide with four ridges on the belt. I don't know of any places in Charleston, as I am not familiar with the area. However, you can order this part on line for about $10 at pcappliancerepair.com and have it shipped directly to your home.
I hope this has been of some help to you.
Oct 27, 2009 | Dryers
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
Cannot enter proper tax rate-need 9.5% for casio pcr t 2000a
Hi.
Please let me know the model number of your machine and tell me what button sequence you are using to set your rate, and I'll try to tell you where you are going wrong.
Mark
Jan 12, 2009 | Casio Parts Cash Register PC Desktop
How do you replace the battery?
If you found the same battery all you need to do is unplug the old one from the player and insert in the new one. The wires should lead to the plug. Use your nails to carefully pull it out. and and you place it back in make sure you hear a click. If not I have explained how I did it here.
I replaced my battery with an old cellphone battery from samsung that was going to be thrown away. You probaly can find one on ebay for about $10. Make sure it is a square 3.7 liion recharageable battery. You may not need to do all of this if you find one just like the one in the player. But it may cost you about 20 - 30 bucks. Only do this if you are sure of what you are doing. I just break up the battery pack and open up the player. This is where it gets tricky. Unplug the battery and put it aside. Examine both batteries. Cut the green plastic from the player battery. Careful. There will be a circuit board on the one from the player. The idea is to remove it with the metal connectors than place it on the cellphone one. Make sure you place it the right way. Than tape it up tight with electrical tape. So it can fit back in the player. They plug in and charge for 4 hrs. And there you have it. If the player can't turn on with out the charger you did not made the connection tight enough on the battery.
Oct 05, 2007 | Samsung YH-925 MP3 Player
GPX PDL805 Portable DVD Player Logo
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
