Question about Dryers
Whirlpool high temp thermostat wiring diagram.
    Master:
    Sergeant:
  • 449 Answers
Pull the back panel a schematic should be back there
Posted on Sep 15, 2010
The pilot lite will light but the main burners wont The high temp light came on but the grease wasn't over temp. I discounted high temp senisor light is still on what do I do now
Most likely the high limit is defective. This can shut down both the pilot and main burners. You can try jumping the high temp sensor leads to see if this solves the problem, assuming it is a standard Robertshaw high limit. Do this only to test, however. Bypassing the high limit can be very dangerous if the thermostat is defective or the oil level is below the sensor bulb. If your high limit has more than two wires, you may need a wiring diagram to determine which leads to jump.
Dec 15, 2014 | Vulcan Kitchen Appliances - Others
On my whirlpool dryer I tested everything on back
If you're getting 240 volts at the terminals, then the parts in between the heat element and those terminals are the timer, thermostat and the high temp safety switch. Every dryer has a pouch with the wiring diagram in it. Use it to see the electrical path and the components to test.
Oct 01, 2014 | Dryers
Whirlpool RF385PXEN COMPLETELY DEAD, NOTHING WORKS,checked the obvious like breaker etc..what is next step. I`m skilled with a VOM Meter, thx
Most ranges from that brand have a high limit thermostat behind the back panel, or sometimes under the burners,it should be closed if good. typically the wiring diagram is either inside of control panel or hidden under the storage drawer.if it has the high limit (also called thermal fuse) the diagram will show you the color wires to it.
Gene
Aug 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool leb 6000 pqo will not heat
check heating coils, high limit, temp selector switch.
Apr 05, 2011 | Whirlpool Dryers
Changed high temp thermostats, maybe hooked wires back up wrong?
you should have a wiring schematic diagram somewhere on the machine otherwise the limit switches are normally wired in series w/element
Aug 15, 2009 | GE DVLR223 Dryers
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer hets to hot
I would check the temp at your outside vent while the dryer is running temp should anywhere from 180 to 225 at the high end and should cycle down from there so u should get like 225 then will drop down to 90's then come back up to the high temp and check on all temp settings. if it does not your operating thermostat may be bad go back over the instructions that came with your thermostat kit to double check your wiring the tech sheet should be in the control panel with the wiring diagram.
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
