Microsoft Excel for PC
Problem for Microsoft Excel for PC
More than 256 characters in a cell in Excel
By SameethKrish on May 16, 2008
When I type in more than 256 characters in a cell in Excel, I am not able to view the contents. All that appears is a string of "#################"!
How do I avoid this
Best Solution
posted on May 16, 2008
Very Helpful)
kpenguin
Rank: Wiz
Rating: 84%, 74 votes
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
Was this helpful?
Yes
No
Solution #2
posted on May 23, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
TELL ME SOME TIPS
Solution #3
posted on Feb 21, 2009
Not Rated)
yugam
Rank: Apprentice
Rating: 0%, 0 votes
Tell me how can you solve this
Was this helpful?
Yes
No
Popular Solutions for Microsoft Excel for PC
Questions and Unsolved Problems for Microsoft Excel for PC
Do you recommend Microsoft Excel for PC?
Answer
Answer
how can u get the pc download to Xbox
Answer
I am writing a user spreadsheet that requires a couple of drop down choices to prompt automatic cell... (More)
Answer
what is formula to use 5 point drop down list to prompt entry of cell value into specific location
Answer
using an excel sheet, assume that sum of some cells is 100.77 and i want to use this sum in other... (More)
Answer
microsoft end user license agreement Excel shows at startup in registered program
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Business and... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
