Question about Microsoft Xbox 360 Pro System Console
When i put a game in and start it plays for a few minuets and then it says disc error then it says to take the game out and clean it with a cloth.it also sounds like the fans are working really loud and for long periods of time
  • 4,102 Answers
Hi it sounds like your not far aways from the dreaded red ring of death, the fans working hard indicates the xbox is over heating really quick and the chances are the gpu and or cpu chip are over heating, now this over heating causes the heat sinks to heat up and these are close to the dvd drive and the heat transfers over and causes the problem you are getting.
now replacing the dvd drive may solve your problem but it wont last long as the over heating will cause the same problem in a matter of weaks
the best thing to do would be to pay someone to remove the x clamps and fit a more secure way of holding the hear sinks in place it will also need a full clean and new heat sink paste using so it is quite a big job.
i charge 25 pound plus parts and if the problem is just the heat sinks and x clamps then it works out to about 30quid but if you do need a drive then your looking at between 40 and 50quid to get it fixed, how ever you need to bare in mind that the damage could all ready be done and the cpu and or the gpu chip could have over heated and fried if this is the case then the unit is scrap and only worth spare parts but as your dvd drive is failing their isnt much else worth anything apart from the case and the fans and possibly the heat sinks depending on which circuit board you have.
shop around and see what prices you can get as it may solve the problem.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 15, 2010
Wii is working fine but when disc is put in it will not play
I see this problem all the time, here are a few things you can try before sending it to www.risingsonltd.com for repairs:
"Cleaning Game Disc
  • Use only: straight strokes when wiping the disc (do not use a circular motion).
  • Use only: a clean, soft, cotton cloth (do not use paper towels, facial tissue, etc.).
  • Use only: water (do not use soap or any other cleaning solution).
  • Do NOT use: solvents such as: benzine, window cleaner, paint thinner, anti-static aerosol spray or abrasive cleaners.
  • Properly cleaning a game disc:
  1. Dampen a portion of a clean, soft, cotton cloth, using only plain water.
  2. With the damp part of the cloth, use straight strokes and wipe the bottom of the disc (non-labeled side) from the inside rim to the outside rim.
  3. After all of the water has been removed, let the disc sit for at least two minutes to completely dry before inserting it into the Wii console.
  4. Try to play the game to see if the problem has been resolved."
If this fails the Optical drive needs to be replaced.
Jun 28, 2011 | Nintendo Wii Console
Reads no disc or see instruction manual every time you turn it on
  1. Some games may need to be cleaned. Clean each disc with a soft, slightly damp cotton cloth (use water only). Clean them from center towards the edges; do not use a circular motion. DO NOT use paper. Once they are cleaned, dry the disc using a dry portion of the cloth and wiping in the same style as you did to clean the discs. After all of the water is gone, let the discs sit for at least two minutes to completely dry before inserting any of them into the Nintendo GameCube.
  2. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  3. Ensure the games are being loaded properly. With the power turned off on the system, replace a Game Disc (printed side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen. Try this with a few of your games.
If Troubleshooting doesn't fix the problem, and it is happening with all your games, then your system will need repair. Check out our convenient repair options.
  • No Game Disc:
    This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
    1. Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
    2. Determine if this happens with more than one game by inserting a different game into the system.
    If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
    If the error occurs with only one game, follow the individual game disc troubleshooting.
  • Troubleshooting - Multiple Discs
  • Jan 09, 2011 | Nintendo GameCube Console
    I was playing a game yesterday and stopped for about 2 hours. I then turned my xbox on and put in a movie, started to get the "open tray" message. I tried several other CD's and games but it...
    Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
  • Note Use ONLY water to clean the disc.
  • Once the disc is clean, load the disc into your console and see if the disc plays.
  • Dec 22, 2010 | Microsoft Xbox 360 Console
    When i put my disc in it says no disc
    No Game Disc:
    Single Disc
    The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
    Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
    1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
    2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
    3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
    4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
    5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
    6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
      • If the disc is cracked
        Review our disc replacement policy to determine how to get your game replaced.
      • If it's dirty, scratched, or shows no obvious damage
        1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
        2. Make sure the game is dry, then re-insert it and see if the error occurs again.
        3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
        4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
    7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
    If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
    Dec 08, 2010 | Nintendo GameCube Console
    The disc in the game cube does not turn. the error say, game disc cannot be read.
    The Disc could not be read:
    Single Disc
    Nov 28, 2010 | Nintendo GameCube Console
    Disc wont read
    Single Disc
    Aug 06, 2010 | Nintendo GameCube Console
    Will not play games
    Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
    Jan 31, 2009 | Microsoft Xbox 360 Console
    Ps1
    If it,s only on this actual game, i,d suggest cleaning the disk itself. FF7 was virtually glitch free.
    another way to resolve this, is to play the game right up until it crashes-glitches. 10-20 seconds before. go to the nearest save point, and make a save. re-load the game and see if you go past now. The PS2 has a limited video memory.
    On ocassions the memory can be overloaded with graphics info,
    My Tip-Trick for cleaning the disk.
    1:- put the disk into an old CD Jewel Case. ( so that the underside is facing upwards )
    carefully inspect the disk for scratches or debris-fingerprints et,c.
    put a small amount of washing up liquid into a small bowl, and add luke( hand Warm Water )
    using a soft cotton or lint cloth, dip the cloth into the solution, and wring out. cloth should be dampened not soaking or dripping. Wipe the disk from the inner ( centre edge ) outwards.
    Step 2:- wipe the disk with a dry clean cloth ( I find the yellow Duster type Cloths Are Ideal ) now breath on the disk, and polish ( buff up ) with a soft clean cloth.
    This should now give you a playable games disk.
    If you still can,t get it to work, try a laser head cleaner.
    Or e-mail me, for my address. send me the faulty disk and i,ll repair it for you.
    Hope this sorts you out.
    MIke @ Compurepair.
    Feb 13, 2008 | Sony PlayStation 2 (PS2) Console
    Open Questions:
    Microsoft Xbox 360 Pro System Console Logo
    24 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
