Question about Distel Grain Case IH Tractor Shaped Mailbox
I just bought a used Distal Tractor mailbox. It need the closure hardware.and stickers for the wheels.all other parts look good. I will need to polish it to bring color back. This is a cool mailbox. It is John Deere green. Any chance of obtaining the hardware and stickers? Bobbi
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
ERROR CODE F-46-8 IN MY COPIER
I think you need to replace the front door interlock switch ( very common part ), and then take some time and adjust the bracket for a really good positve closure on the switch....leave the display panel off during this adjustment so you can get a good look at the switch closure. There is no factory adjustment on the bracket- you might have to bend part of the bracket to get a good closure. Open and close the front door a couple of times just to be sure and there you go. This front door interlock switch is a common failure on the 7033, 7040, and 7045's and will give you all kinds of crazy symptoms.
May 11, 2014 | Konica Minolta Copier Toner 7033/7040...
19.5 hp briggs & straton ride on how to remove 2 pistons
You need to remove the engine from the tractor. un bolt and lift the cylinder head off, remove the ring off bolts on the crankcase closure plate and remove, undo the big end bolts and push the con rod and piston out through the top of the cylinder
Apr 21, 2013 | Craftsman Garden
Thanks: belt is slipping and I got it used and have used it for 8 years. Possible other problems. I need to remove the deck. Thanks again
hello qp..... the belt is slipping because it is old and stretched. Replace it and you will be good to go. Regarding the deck... you must drop it in order to replace the belt. look under the tractor to see how the deck attaches. do this on a level spot so the tractor won't roll. generally you begin by undoing the belt from the drive wheel in the front and then dropping the front by releasing the mechanism that holds it in place.
the last part is to disconnect the rear. Joe
Jun 06, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Craftsman model 917.273482 and the deck is riding on the left wheels when it is in the fully lifted position. What did I break in the suspension of the left side I can't see anything wrong.
from the manual I just looked at,, the wheels attach to the deck on that model,, so some part is misaligned or bent,, here is the page showing the deck and wheels,, maybe it will help you http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273482/0247/1509200/P0308003/00010?blt=06&prst=0&shdMod=917273482 You can look up the entire lawn tractor at searsdirect ,, Hope that helps Please take a moment to rate my response Thanks Good Luck
May 28, 2011 | Garden
My Craftsman Lawn tractor (several years old) is a Model No. 27081, 19.5 HP automatice transmission, 42 inch, two-blade mulching tractor. I actually had one of those warranties where they fix it forever...
Parts for your riding mower (except engine) should be available through www.searspartsdirect.com for at least 10 years from date of mfg and sometimes as long as 30 years. When you go to the website, you will need the tractors model number. It is located on a sticker on top of the rear fender assembly. Raise the seat to see it. It probably looks something like 917.385880 . The engine parts are available through sears or through other online sources such as www.partstree.com or www.milacalawn.com . For engine parts, you will need the model and serial numbers from the engine. These numbers are usually located on a metal plate that is riveted to the upper shroud, or on a sticker on the side of the upper shroud. Find a local mower repair shop, they will also have access to these parts for you. Your local shop will usually be alittle higher in price, but will offer installation advice that is priceless.
Aug 31, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a belt routing diagram for wheel horse raider 10 lawn tractor
have a raider 10 in gravenhurst with a deck sticker that shows the belt routing......if you still need the diagram, let me know
Jul 14, 2010 | Garden
Distel Grain Case IH Tractor Shaped Mailbox Logo
77 people viewed this question
Top Distel Grain Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Distel Grain Toy Expert? Answer questions, earn points and help others
