Question about Dell 4210X DLP Projector
I need to throw the image 30ft but I only need the standard 8'X6' image size is there optional lens I can use
  • 1 more comment
  • omri_davies Sep 15, 2010
    if there is an optional lens what is it
    I need the throw distance this projector gives me but the image size at that distance needs to be smaller. Is there a lens or other option that will do this for me
    I checked it out but it doesn't tell me what model I need
    President:
  • 2,777 Answers
I think I was helping you earlier, but just in case it was someone else, there is no optional lens for this model. Did you try contacting Dell?
Posted on Sep 15, 2010
    President:
  • 1,932 Answers
  • 944 Answers
Hi.
You can throw the image till 3.9ft. ~ 32.8ft.with normal lens itself.But you don't have any optional lens for standard 8\'X6\' image size.There is optional lens but you cant maintain the standard images size of 8\'X6\'.Because of the distance.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 15, 2010
    Optional lens.F-Stop: F/ 2.4~2.66 or F/ 2.55~2.83
    Focal length, f=18.2~21.8 mm
    1.2X manual Zoom Lens
    Throw ratio =1.6~1.92 wide.
    You can only get in dell authorized service center.
How do I select a monocular lens?
Having a monocular is a great alternative other than carrying a pair of binoculars. They are significantly more compact, lightweight and portable but they come with only the half of the size of binoculars. The following article talks about how to Select the best monocular lens between your budget and needs.
Need to consider the points below:
  • Monocular vs. Spotting Scope
    A monocular significantly featured a compact and portable design. Monocular lenses that are bigger generally have more power, larger lenses and wider views are known as spotting scopes. A spotting scope will be notably greater and heavier than a typical monocular which are frequently used for bird watching, hunting, or spotting subjects from a static position. In case require better performance, and you are compatible with the size or weight, then you have the hardly better option than a spotting scope
  • Good Monocular Power
    The power or magnification are the things that you should consider first when choosing a monocular lens. This device typically has a higher magnification of 6x to 10x which will allow you to see further and in more detail. The monocular with 9x or 10x magnification will usually slightly high priced more than 6x or 8x ones. The good thing is, about this device, that you can get the same power of binoculars, but they are only half of the size of their counterpart.
  • Right Lens Size
    If you look at the specifications of a monocular, you will find two numbers. For instance, 8×25; which means 8x, the first number, denotes its power, and 25mm, the second number, represents the size of its lens.
    A monocular comprises with a lens of 20mm to 42mm. With a bigger monocular lens, you can observe see a wider view, and will also result in a better, sharper image while looking through the device. The downside is that the larger the size of the lens is, the heavier and bigger the device will be.
  • Monocular Size and Weight
    On the whole, an 8×25 or 10×25 monocular is considered to be a pocket-size or compact device which will simply be fit in your pocket. They usually come with a small carrying bag. The pocket monocular works as a cool device. They are very portable as it is easy to carry them around everywhere - keeping in the car or in the pocket when climbing. These devices are low-priced and can also serve well.
    You will have to keep it in your mind that an 8×25 or 10×25 pocket monocular is very small, so you cannot expect too much performance from it! These tiny monocular have a small lens but can provide a very limited view though they have good power. At first, you will need to detect your subject and later use the monocular in a "point and shoot" style. It is not at all easy to use them since they have a small eyecup. If you want to enjoy a wider, sharper and brighter image, then you should always opt for a 30mm to 42mm monocular.
  • Night Vision Monocular
    If you are planning on buying a monocular in order to use at night or whole darkness, then you should go for a night vision monocular. IR illuminator is built-in these devices which will increase your night vision capability. Having less magnification, you can use them normally to get a better image and off course less fuzzy. These monocular usually come in different sizes, magnification and price range.
This guide helps you to choose a monocular lens that you are looking for.
Mar 19, 2018 | Optics
Need to reduce size of projected image from Senario Torpedo Entertainment Projector. I do not have a user's manual. How can the size of the image be changed?
Many projectors have you twist the lens at the front of the unit (or have a separate adjustment near the front). This unit may not have the option, in which case you will need to adjust the image size by moving the projector closer to the screen.
Oct 27, 2013 | Senario Torpedo Entertainment Digital...
Mitsubshi sl4su
THis is a very short throw even for a "short throw" lens. I would verify that this is the proper lens by its numbers and verify what you should be seeing by its tech specs (focal distance./image size to be expected)
Jan 09, 2013 | Mitsubishi SL4SU ColorView Multimedia...
There are dots in my screen
ok firstly where are the dots? in the projected image? or what? if they are in the projected image you may need to clean the lens....
Feb 26, 2011 | Eiki LC-X6 XGA LCD Medium Venue Projector...
Price for acer x1161 model dsv0817 lamp
Street Price (USD) : $436 MSRP (USD) : $499 Brightness (Lumens) : 2500 ANSI Eco-Mode (Lumens): 2000 ANSI Contrast (Full On/Off) : 4000:1 Variable Iris: No Audible Noise: 30.0 dB Eco-Mode: 26.0 dB Weight: 2.2 kg Size (cm) (HxWxD) : 8 x 27 x 19 Std. Lens: Focus: Manual Zoom: Manual, 1.10:1 Throw Dist (m) : calculator.gif 1.5 - 12.0 Image Size (cm) : 86 - 770 Optional Lenses: No Digital Zoom: Yes Digital Keystone: Vertical Lens Shift: No Warranty: 1 Year Performance: H-Sync Range: 30.0 - 100.0kHz V-Sync Range: 50 - 85Hz
Nov 07, 2010 | Computers & Internet
Can canon lv-53 projector run on USB....
MSRP (USD) : $1,299 Brightness (Lumens) : 1250 ANSI Contrast (Full On/Off) : 300:1 Variable Iris: No Audible Noise: 32.0 dB Weight: 2.2 kg Size (cm) (HxWxD) : 8 x 28 x 21 Std. Lens: Focus: Manual Zoom: Manual, 1.20:1 Throw Dist (m) : calculator.gif 1.3 - 6.5 Image Size (cm) : 86 - 508 Optional Lenses: No Digital Zoom: No Digital Keystone: Vertical Lens Shift: ** Warranty: 3 Years Performance: H-Sync Range: 15.0 - 80.0kHz V-Sync Range: 50 - 100Hz Compatibility: HDTV: 720p, 1080i, 1035i
575i EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes Display: Type: 1 cm 3 LCD Native: 800x600 Pixels Maximum: 1280x1024 Pixels Aspect Ratio: 4:3 (SVGA) Lamp: Type: 160W UHP Life: ** Quantity: 1 Speakers: Mono Max Power: ** Voltage: 100V - 240V FCC Class: B Special: ** Status: Out of Production First Ship: Nov 2003 Last Ship: Mar 2006
May 08, 2010 | Canon LV-S3 Multimedia Projector
Figures on barrel of lens when open ie 1:15.3 etc
Those are the magnification factors so 1:1 means the image on the camera sensor is the same size as the image in real life - often used in macro
On your lens, looking at images on line I think you have 1:8 at one end and 1:38 at the other So if you comapre the size of the image on the sensor, to the size in real life
  • 1:8 - real life will be 8x the size
  • 1:38 - real life wil be 38x the size
http://www.ehow.com/about_5040403_magnification-ratio.html
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 06, 2010 | Sigma 18-125mm f/3.5-5.6 for Digital SLR...
Epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
How do I print 4x6 photo on 8 1/2 x 11 paper?
Easiest is to open your photo with 'Windows Picture and fax viewer', follow the prompts, and the final window will give options to print "full page', Wallet size" 4"x6", etc
Mar 01, 2009 | Epson Stylus NX400 InkJet Printer
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Dell 4210X DLP Projector Logo
64 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
