Question about Goodman CKL24AR24 Air Conditioner
I have a 6 year old Goodman ClJ24. Today I noticed that the motor in the unit was running backwards.Instead of blowing out hot air from the top, it was sucking in air. Also unit suddenly is not cooling.
  • Goodman Master
  • 43,501 Answers
Yes, once in a while the motor will just start to run in reverse...this is not fixable... you will need to replace that motor...and as you can see if it is not running correctly you will not get proper cooling...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 15, 2010
Testimonial: "Thank You. I will give this a try and see what happens."
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Unit outside isnt working
Replace the run capacitor, too.
Jun 23, 2009 | Goodman CKL24AR24 Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Goodman CKL60-1 Condenser Fan Runs OK, then stops
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Motor for Air handler will not stay on.
sounds to me lik eyou may have a bad run capacitor. this will most likely be an oval shaped device directly wired into the motor. Be very cautious when you remove this and make sure you discharge it to a grounding source as it will shock you.
Jun 11, 2008 | Heating & Cooling
Exhaust Fan (outdoor blower?) shuts off after 1 minute, and motor feels hot
sounds like your condenser fan (the outside blower) has gone bad or the capacitor (small silver box looking thing attached to the motor). the way to test the cap. is with a digital meter that can test for micro farads. the reason it gets hot is you have electricity going to the motor. normally it would transition that energy to motion energy. however since the motor is not turning that energy has to go some where, so it turns into heat energy. your best bet is to replace your condenser fan and capacitor. that is if your comfortable with that type of repair. otherwise call someone out to repair and tell them what your make and model is so they can bring the parts with them and save you some money. hope that helps
Jun 11, 2008 | Goodman Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
380 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
