Question about Canon NP 7130 Black and White Copier
Bad copies, and I feel it is something I can do by adjusting something in the copier. The copies are on the darker side of the adjustment but we have everything as light as it will go.
  • Canon Expert
  • 1,326 Answers
Try cleaning the optic's & look at the drum unit, you may need a new drum & blade
Posted on Sep 15, 2010
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
How can adjust faint dark adjustment?
open the front door, remove mounting screws of toner hopper at top right corner, flip open hopper cover, slide out hopper , above the drum unit in center there is corona assembly, detach connection of corona cleaner, on the right side of corona assembly there is a black plastic lock, loosen the screw and slide lock upwards, slide out corona assembly, on the upper side of corona assembly there are clear plastic adjustment screws, if u want to make copies darker- turn all of four screws evenly counter clockwise and if u want to make copies lighter- turn all of four screws evenly clockwise.adjust half turn every time and check. revert whole process to put all together. make sure u connect hopper connector at the right bottom side of the unit after sliding in the unit.
Feb 10, 2011 | Canon imageRUNNER 6000 Copier
I WANT TO COPY A DOCUMENT DARKER
There should be a menu item or button that allows you to adjust the copier's brightness or contrast. The icons may be represented as a circle with half-white, half-black center, or as a circle with lines surrounding it, like a sun.
It would help to know your model of copier, or at least your manufacturer.
Jun 21, 2009 | Office Equipment & Supplies
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
We cannot seem to make a copy darker??
i would suggest that 1st you do the auto gradation adjustment full adjust under add function /adjustment cleaning then under additional functions look for one that says printer settings you can adjust black density under that setting
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
Cartridge Finishes early
Unfortunately that is a technical issue.
1-adjustment of the Seperation
2-adjustment of the developper
3-adjustment of the Primary bias
4- etc.. etc...
You need a tech to go in and see which adjustment needs to be reset or calibrated. Most adjustments are done in the service mode but you still need to know how anad which one. The SERVICE manual is the only thing that will tell you and how to adjust.
Aug 14, 2008 | Canon Office Equipment & Supplies
Sharp AL-1340
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Apr 12, 2008 | Sharp AL-1641CS Laser Digital Copier
Canon NP 7130 Black and White Copier Logo
old marine
old marine
