Question about Behringer Pmp3000 16 Channel Audio Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the one in amplifiers.. ACsound
  • Behringer Master
  • 5,603 Answers
Some mics will require the trim gain to be full on. Check the mic gain by pressing the PFL for each channel and set trim to be below the clipping level with maximum vocal into the mic.
There are some low output mics that may be inadequte as far as output goes. Shure SM58 are industry standard mic... If you don't have one to try, borrow one to test with.
After that, the slider, EQ controls and the MAIN sloder has all the control.
Posted on Sep 15, 2010
We have a PMP4000 running multiple mics and instruments in a small church space. We are not getting very much volume and the sound is very fuzzy. Any recommendations?
You have NOT told us what speakers you are using or anything to help us help you. That mixer will produce about 250 watts a side into 8 ohm speakers. That should fill a 30 by 50 foot area. You will need at least 15 inch speakers. Proper mixer setup is important. Look at videos on the subject on YouTube for instructions. Many people use too much high frequency EQ setting. Set the EQ flat to start. Use minimum of reverb to start. Use good quality mics with XLR to XLR cables... none of this Radio Shack or Karaoke quality. Minimum mic cost iis around $90 for decent ones... or about $70 when bought in lots of three or more. For your speakers make sure they are elevated on speaker stands. Use the PFL to solo each channel and set the TRIM level for each as the first step.
Oct 29, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Soundcraft Gigrac 1000st distortion in the mic inputs. The rca line in is fine and clean. No effects on the mic pre sounds like its breaking up at any volume level. really dissapointing.
You should be using Dynamic mics such as a Shure SM58. They go into the first FOUR channels and if there is excessive gain and distortion, push in thee Pad button below the connector for those four channels. Inexpensive consumer microphones used with some Karaoke home systems are not suitable for this unit. You should be using XLR cables on the mics (balanced lines). The Pad buttons reduce the gain by a fixed amount of -20 Db for mics that have too much output to be controlled by the gain controls right above the connector. Ideally those should be no less than 12 o'cloock for good signala to noise ratio. Additional channels beyond the first four do not have as much gain and they do not have the -20 Db pad option.
May 15, 2011 | Soundcraft GigRac 1000st Powered Mixer...
I turn it on and at the volume set @ U or straight up(midway) nothing comes out. if you turn it all the way up of course you get alot of buzz and barely get any sound from a mic or mixer signal,etc. could...
Make sure you are using BALANCED line to this... XLR connections boyh ends. Make sure ALL interconnected devices are powered from the same receptacle or power conditioner. Test your cables... they do go bad. This unit REQUIRES line level input. Do NOT expect a mic to drive it directely. Make sure your mixer uses the XLR outputs and is powered from the same receptacle, even if you have to run an extension cord to it. This is a bi-amped speaker so there are independent amps for high and lows. With nothing out and known good in there is very little electronics before the signal is split to the separate amps. At line level, your volume control should probably be about 2 o'clock with the EQ's straight up flat.
Apr 25, 2011 | Mackie TH-15A Active DJ Powered THUMP...
HI,I have a VMX1000USB mixer and I cannot get any sound when plugging a microphone in any of the rear jack sockets, as opposed to the XLR sockets on the top of the unit. Can you please advise what may be...
The XLR are intended for mic and as such they have the gain needed to use mics.
The connectors on the back are LINE LEVEL connectors. To use a mic with these, you will need to have mic preamps to send adequate levels into the jacks on the back of the unit.
Feb 14, 2011 | Behringer VMX1000USB VMX-1000USB DJ MIXER
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
Hook up eventide harmonizer to the pmp 6000
There are many models of the Eventide and how to hook them up will vary and depend if you have multiplle mics that are to be serviced. If you have multiple mics, I would be tempted to run the mics into some of the channels of the PMP but tur their faders to zero and send them to MONITOR 1. Come out of the MONITOR 1 jack to go into the Eventide and then run the Eventide into one of the line inout channels like 19/20. You would need to use balanced connections and some adapters from XLR to 1/4 inch to make the connections. There are MANY ways to configure this and depends what you are trying to do. If all audio is to go through the Eventide, then wire it as an "INSERT" for the power amp. This would require a special cables.
Jan 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
1) how to make my amp record....because its not working when i try... 2) do i have to a cord in line 1 and 2??? 3) do i have to plug in the cord in :.....line in or line out??????
You will use microphone with balanced XLR connector into the XLR mic input. Note, the ALpha does NOT have phantom power so you cannot use condenser mics.
A guitar can be plugged into the hi-z instrument 1/4 inch jack on the left front of the unit.
To use the line 1/4 inch inputs you will use BALANCED TRS 1/4 inch cables from your source.for these channels. The level on these needs to be line level.
The line outs are for sending audio out to an amp. There appears to be RCA outputs you can use as well.
I am not sure what you mean by making your "amp record"... An amp PLAYS the audio, usually into a speaker.
If you are trying to play a guitar through your amp AND record, then you will connect your guitar to the Alpha, the amp input will have a cable from say Line 1 OUTPUT and when recording wou will have the echo feature on so your guitar is passed through to the amp.
Jan 09, 2011 | Lexicon Alpha Personal Recording Studio
When I plug in my XLR microphone to my Behringer PMP3000 it only works on the Main/Mon function not the Main L/R function, and when it is working it only amplifies through one speaker. WHY???
Check if the PAN control for that channel is set at 12 o'clock position.
You can "pan" the mic to either L or R speaker or anything between.
On the Main/Mon setting, the level sent to the Mon side is controlled ONLY by the Mon level pot for that channel.
Oct 04, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My mic output is very weak. Music comes out great. I have to set the levels all the way up to get any mic sound and usually there is a lot of clipping. You need to almost scream to get any sound with a...
Thiis amp has plenty of gain for mics. Make sure your mic has a good XLR to XLR cable (balanced) and connects to the XLR input connectors. If you have 1/4 inch jack cables that aren't TRS balanced on the mics, get rid of them and get XLR's.
Then push the PFL button down (LED will light red) for a single channel with a mic and adjust the trim (top knob for the channel) so that the level peaks without clipping on the main LED display when highest input to the mic is being generated. You should not get clipping then during operation.
After that you use the slider tio adjust the level for the mic. The MAIN slider should be at least up around -10 to zero during operation. If your main slider is way down, then you haven't balanced your channels properly. Do the same for each channel as the instructions for the mic above. If the gains of the other inputs are too high and the MAIN slider too low, this is what is causing your problem.
Typically the trims for mics like Shure 58 are about 3 o'clock.
High level guitars may have trims anywhere from 9 to 3 o'clock.
Ideally you will want your channel sliders to be between -10 and zero.
Sep 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
175 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
