Question about KitchenAid KESS907SSS Electric Kitchen Range
KitchenAid YKESS907SS00 electric oven and glass top. The oven takes around an hour to preheat to 350 degrees! Doesn't seem normal to me. Any ideas what the problem might be?
WhIzAtIt
  • 136 Answers
SOURCE: GE Spectra XL Oven does not maintain oven temperature
The most logical solution for your problem would be a faulty thermostat, but yet at the same time i dont understand how it would heat to the temp desired then not come on at all. I would definately change the thermostat to start off with. Let us know :-D
Posted on Sep 14, 2007
watugot
  • 290 Answers
SOURCE: Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Posted on Oct 29, 2007
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
MNTECH
  • 1543 Answers
SOURCE: Oven takes a long time to preheat
You don't list a full model number or how old this range is, or how long / how often you have this problem, but generally it sounds like the oven ignitor is not quite drawing enough amps to allow the gas valve to open regularly. It could be a low voltage related issue, but most likely is a failing oven ignitor. ( WB2X9154)
Posted on Sep 04, 2008
  • 409 Answers
SOURCE: TAKES TO LONG TO PREHEAT
sounds like the thermostat may be open and nees to be replaced. have a technician take a look at it.
Posted on Sep 13, 2008
My oven seems to take a really long time to preheat -- about 20 minutes to reach 350 Fahrenheit. Is that how long it is supposed to take? Thanks
That would seem to be longer then normal...
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 04, 2011 | KitchenAid Ovens
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Open Questions:
See all KitchenAid KESS907SSS Electric Kitchen Range Questions
KitchenAid KESS907SSS Electric Kitchen Range Logo
131 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
