How to adjust my computer fan - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
This is one program, http://www.almico.com/speedfan.php
Would like to state though, be sure the fan in question isn't spinning at a high rate, due to a fault within the computer.
1) Computer is dirty inside.
A) Fan for the Processor, and Heatsink on the Processor, are dirty, causing the Processor fan to operate at a high rate.
[Some computers have a fan mounted directly on top of the Heatsink, sitting on the Processor.
Some computers use a computer case fan to push air through a plastic shroud, which envelopes the Heatsink.
Typical Fan/Heatsink combo,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3451342&CatId=493 ]
Computer unplugged from power, Anti-Static Precautions taken, use a can of compressed air, (Or two if needed), to clean the inside of the computer.
Don't forget to clean the inside of the Power Supply.
[Using the plastic 'straw' provided, (Should be used at all times), insert the straw into the ventilation holes of the Power Supply's case.
Suggest starting with a hole located towards the top of the Power Supply's case, and directing the air flow towards side to side, and top to bottom.
Then move towards the bottom ventilation holes.
Come towards the back of the Power Supply, and clean the Fan's blades, and center hub. Also the surrounding shroud around the fan's blades.
If you find heavy 'gunk', (Dirt, dust, etc.), that the compressed air won't remove, suggest you use Q-tips.
You don't have to remove the 'gunk' with the Q-tips, just 'disturb the surface' of the gunk with them.
Then follow with air.
2) Thermal paste in-between the top of the Processor's case, and the bottom of the Heatsink, has dried up, or partially dried up.
Another situation that causes the Processor to overreach it's thermal limit, and cause the Processor fan to operate at full speed.
Computer unplugged from power, Anti-Static Precautions heeded carefully, the top of the Processor's case, and the bottom of the Heatsink are cleaned THOROUGHLY, and then new, fresh thermal paste is correctly applied.
3) Some fans have four wires.
A) One for the Positive connection,
B) One for the Ground, (Negative) connection,
C) One for the sensor that monitors the RPM, (Revolutions Per Minute) of the fan,
D) And the last wire is a sensor wire, that allows the computer to vary the RPM's of the fan's speed, as needed.
Ensure that the connection of all four wires is tight, and especially the sensor wire connection. A loose connection will cause an out of control fan speed.
Some programs, such as an intensive game, will cause computer case fan/s, and a Processor fan, to operate at high speed.
A necessary thing to keep the Processor from overheating.
For any questions you may have regarding what I have stated above, please post in a Comment.
Would appreciate hearing back from you.
Posted on Sep 15, 2010
How Do I Know that the Huawei S5700 series switch's Fan Operates Normally in Intelligent Mode?
The fans can work in the intelligent mode or forcible mode.
In the intelligent mode, the fans start to operate only when the ambient temperature goes higher than a specified value. In V200R003C00 and later versions, you can run the display fan speed-adjust threshold minus command on the switches that use the intelligent heat dissipation mode to view the temperature thresholds for the fans to start and stop running. The set fan speed-adjust threshold minus command can be used to lower these temperature thresholds.
Intelligent heat dissipation:
Huawei S5700-24TP-SI-AC
Huawei S5700-24TP-SI-DC
Huawei S5700-48TP-SI-AC
Huawei S5700-48TP-SI-DC
Sep 14, 2017 | Huawei Computers & Internet
Clutch fans Adjustable temp?
Go with a Thermal fan and clutch.
The thermal fan clutch is a little more sophisticated and operates, as the name implies, in response to underhood temperatures. When the engine is cold, the fan is disconnected; when too much heat is generated, the fan is allowed to cool the engine. A bi-metal thermostatic coil mounted at the front of the clutch senses the underhood temperature and operates the clutch accordingly.
Jun 05, 2014 | Hayden-Harnett Hayden 2582 Thermal Fan...
Fan won t go off when computer shuts down
restart the computer and HOLD the keys CTRL+f2 or esc depend of your model, mark, and go to adjust the FAN.
if the problem remain, use the software diagnostic coming with the computer, or download from your computer supplier, or get support via ONLINE chat free, in order to determina if is faulty.
GOD BLESS YOU
Jul 05, 2013 | Alienware PC Systems Computers & Internet
C7 is code
C7 is displayed when the primary fan (the one in the middle just under the copper heat exchanger) does not spin or the computer does not recognize that it is spinning. There is a plug on the back of the fan. Make sure it is plugged in all the way.
This also happens when the computer gets damaged because the unit is plugged in to an extension cord, power surge or poorly adjusted combustion (most contractors lack the proper equipment to adjust the flame on high efficiency equipment). I have been to over 500 tankless water heater installations and found every one of them were not adjusted at all! It can also be a damaged fan caused by an improperly installed exhaust pipe.
Jul 30, 2012 | Bosch AquaStar 2400ES-NG
Can you adjust the speed of the fan on an Apple MacBook?
A lot of people don't realize that they canadjust the cooling fan speed on their Apple Macbooks and it can make a bigdifference. This article gives instructions how to do it.
Jul 17, 2012 | Apple Macbook Air CPU Cooling Fan...
Compaq presario sr2172nx shuts down unexpectedly. Very loud fan. How do I adjust those settings in the BIOS?
The fan is probably heat-sensitive, and your computer is probably overheating, despite having the fan spinning at 100%.
Disconnect the AC power.
Remove the side-panel.
Using a can of compressed-air, give your motherboard & CPU & power-supply a "blow-job", to remove all the dust that has accumulated, and is acting like a blanket that is trapping the heat.
When your computer is running at a lower temperature, you won't need to adjust the BIOS-settings.
Aug 18, 2010 | HP Compaq Presario SR2172NX Refurbished...
New Fan for buffalo terastation ts-1.0tgl/r5
just the fan, with 3 wires, as long as it has the 3 wires then you can adjust the speed... most fans do come with this 3 wires setup now adays
Apr 15, 2009 | Buffalo Technology TeraStation Home...
My computer fan is running continuously, from the time it turns on. (even before booting in to windows xp) why does my hard drive fan kicks in all the time - its loud and annoying
The fans in most desktops do run whenever the unit is on. Only high end/ performance/ or self built systems usually have self adjustable fan speeds.
Mar 12, 2009 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
Presario 2200 CPU fan appears to be dodgy
Not really, since the fan is controlled ny a thermal sensor on the Motherboard. You may want to start by having the fan and heatsink assembly replaced.
Jan 10, 2008 | HP Compaq Presario 2200 Notebook
Fan controller does not work! Power Up (TC3J-4048)
It is bad out of the box. either take it back or email whoever sold it to you and get a new fan. You should not have to pay for a new one.
Dec 30, 2007 | Power Up (TC3J-4048)
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
