Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
My mower starts fine and then it idles up and down and up and down and dies? I have changed oil, plugs, fuel filter, air filter
    Problem Solver:
  • 4 Answers
First thing to check would be the base governor setting.This should be done by someone with small engine expertise.Can be fatal to engine and do bodily harm if not done right.Other things to check would be air leaks where carb manifold attaches to heads.Remove air cleaner assembly to gain access to carb linkage and manifold.You will need a can of carb cleaner to perform this check.Start engine and hold throttle at just above idle speed and carefully spray area where manifold attaches to head,do this on both ends of manfold and at carb base,area where carb mounts to manifold,if leak is present the engine will either die or their will be a change in rpm,s.If no leaks are found in these areas have carb cleaned,it is very likely there is dirt in the carb.You can do the same as above,start engine and hold throttle just above idle and spray carb cleaner into carb,engine will try to stall when doing this,only spray carb cleaner in carb while engine is running.If this doesn't help have carb cleaned and adjusted.Info from small engine tech with forty plus years experience.
Posted on Sep 19, 2010
Mtd yardworks walk behind starts then idles down shuts off after 20 seconds whats wromg
Usually when a mower dies, it is a fuel delivery problem. Have you changed the filter? Is the gas fresh. Also has the air filter and spark plug been changed recently? the Carburetor may need to cleaned. Take the air cleaner off and spray some carb cleaner in the throat of the carb. Also, take about 1/3 bottle of carb/fuel system cleaner and add it to the gas in the tank.. For the new mower engines, there is no fine-tune adjustments on the carburetor. Also clean the exterior of the carb with carb spray.
May 20, 2014 | Mtd Garden
I have a cub cadet 1500 series with 200 hours! I just changed oil filter, air filter, fuel filter and spark plugs! I started up my mower and it is now running like ****! The idle goes up and down, if I...
I think runnng out gas. Your fuel cap vent and unhook fuel line from carb. and see if fuel run out. And check if fuel filter in the right direction.
May 06, 2012 | Garden
My 03 tahoe dies when it comes to a complete stop... I can start it but when I give it gas in the park position and let it come back down to a idle it dies... I have replaced all spark plugs and wires... I...
thats what it sounds like, a bad or clogged up fuel filter. if it bogs down when giving it gas, or going up a hill. its probably the fuel filter not letting enough fuel to engine. that is why it stalls at a stop. if this helps but not fully. check or clean idle air control motor. this is what maintains proper idle of vehicle. have a good day !!
Mar 31, 2011 | 2003 Chevrolet Tahoe
Mower starts and stops with in a few seconds
Ok your not getting fuel into the carburetor it sounds. This could be either your carb.needs cleaned or your low idle screw on the carb. needs adjusted. The idle screw is located directly underneath the air filter. Remove filter and turn clockwise all the way and then counter-clockwise 2 1/4 turns, then test. Adjust until it sounds about right.
Sep 22, 2009 | Toro Lawn Mower With Toro Power Tools
Mower starts and runs fine and about 15 minutes it idles down and hardly runs but won't die.
changed fuel hose,spark plug, and filter lawn mower starts but wont stay on. please help
May 05, 2009 | Craftsman Garden
After the spring tune up, new plugs, oil and
your fine filter inside the fuel tank may be partially blocked and only allowing the motor to idle ok but not supply enough fuel when the motor is under load
Apr 25, 2009 | Garden
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
523 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
