Question about Microsoft Windows XP Professional for PC
I can not format d drive on my pc.there was duel operating system.one was windows 7 and another is xp.xp was on d drive and it detected pirated by microsoft and was notifying windows genuine advantage.i adready deleted all files and folders on d drive but unknown ones that not visible on d drive but it shows that it takes some memory space.now what can i do to format it?now i use windows 7
    Scholar:
  • 120 Answers
Use this
Active@ KillDisk - Hard Drive Eraser is powerful and compact software that allows you to destroy all data on hard and floppy drives completely, excluding any possibility of future recovery of deleted files and folders. It's a hard drive and partition eraser utility.
free program
http://www.killdisk.com/
Posted on Sep 15, 2010
Can i remove a pirate copy of windows 7 and replace it with my genuine copy of windows xp
you would need to insert to XP disc in the cd drive and reboot the pc. As the pc reboot whatch for "Press any key to boot from disk". This will make the pc bypass the hard drive and load the boot file from the XP disk. Once you have answered the inital start questions, it will give the option to format the hard drive or create an extended drive. If Win 7 is not needed any more, I strongly suggest doing the format and have a fresh, new install of XP, Genuine copy.
Good luck.
N.I.T.
Jun 14, 2014 | Microsoft Office Professional 2007 Full...
Tip
When you are running a pirated operating system
when you are one of the pirated running system in the world...
you should know this....
first when you first use your computer remember to turn of automatic updates of your pc...
it is the one who cause why microsoft detecte that your operating system is pirated... it will display a message like your windows do not pass genuine validity..
if your are messed up it it...i rather suggest that you format your pc and after formatting remember to turn off automatic updates...
or just buy an original Os and you will never hook up with this problem...
on Feb 07, 2010 | Computers & Internet
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
Dec 14, 2011 | Samsung R580JBB2 Notebook
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
I would like to change my windows xp to Linux version,what should I do?
https://wiki.ubuntu.com/WubiGuide
You can download a free copy of wubi,Make sure you have enough space on your hard drive.You can install this just like any other program.It turns into a duel boot system.Just make sure to down load from the orange button.Worked great on my win 7 laptop was faster than 7.
May 05, 2011 | PC Mall Linuxmandrake Operating System 72 ...
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
If i will open my system then, every time my system desktop is going to black and display a message like "you may be a victim of software counterfeiting. this copy of windows did not pass genuine windows...
well, is this a legal cd of XP? or did you pull it from the internet? if it is a original version of xp, please contact Microsoft, they will reactivate it, or sent you a new xp cd.
Aug 23, 2010 | Microsoft Windows XP Professional With...
How do i uninstall windows vista like windows
you cant uninstall it...once u have it on there u can only format as mentioned above. its not that bad...however, win 7 is awsome....give it a try.
Nov 02, 2009 | Microsoft Windows Vista Ultimate Edition
Need to install a pirated version of vista.
Since it is a DELL, it was sold with a license to use Windows XP.
So, the very-easiest solution is to contact DELL.
For about $20, you can get a replacement set of CDs/DVDs, and then you can install a _LEGAL_ version of Windows XP.
Note that "Windows 7 Release Candidate" is a free download;
it is the follow-on to Vista.
So, until June 2010, you can use Windows 7 for *FREE* -- and then pay an "upgrade" fee in July 2010, if you still want to use Windows 7.
Jun 01, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
