Question about Kitchen Ranges
Sundance spa sentry control 605 hq . system don't start and run. where do i start?
al_kupchella
  • 843 Answers
SOURCE: I have an older Sundance Sentry Spa model 605.
If you can find a higher rated GFCI receptacle it may help. But the first thing is to use 12 ga wire (NOT 14), and to get a good and tight connection to the load lug. Use the screw terminal, not the push-in holes. If you can remove the screw, do so. Then shape the end of the wire into a nice hook and then use a hammer and anvil to flatten it slightly. Then insert the screw nice and tight. If you can manage a 10ga wire, use that.
Posted on Aug 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Tub/panel scematic-ideas for fixing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!
Posted on Sep 15, 2010
  • 990 Answers
SOURCE: on the sundance spa optima the watchdog error came
You probably just have an air lock at the pump. This will keep it from pumping water. You just need to open the drain valve for a few seconds to relieve the air. when it runs water you should be good to go.
Posted on Nov 28, 2010
Coastsider
  • 331 Answers
SOURCE: OH message showing on sundance spa sentry help!!!
If you are seeing OH and FLO codes, you need to shut it down at the circuit breaker, until it can be serviced. It likely needs a new circulation pump and the flow or pressure switch may be failing to shut down the heater causing the boiling
Posted on Aug 15, 2012
uspartscente
  • 717 Answers
SOURCE: Sundance 605 Series spa. Recently had the motor replaced, but now the motor runs continually. Installer said I need a new board. Is there anything else that could cause this?
When a spa runs continually it can be a bad board but we would have you replace the Temp Sensor first. If the spa is not heating it could be the pressure switch is not working or it could be the Temp Sensor or the High Limit sensor.
Check the topside panel to see if the heat indicator light is on. If it is NOT on then your pressure switch needs to be changed.
If the Heat indicator light IS on then you probably just need a Sensor.
It is always possible that the heater relay on the circuit board is bad.
Rod
US Parts Center
888-521-6183
Posted on Apr 01, 2013
I need a wiring diagram for a '94 400 series sentry spa
Not available, without a lot of digging, maybe somebody has one and may upload it somewhere for you?
But in the mean time...
I might be able to assist!
What is the problem? What do want to do? What do you need to know, about your Sundance Spas, 400 series?
May 31, 2015 | Pool & Spa
Sundance spa
may be getting water in the blower and the safety bypass is turning it on to blow the backed up water out of those lines..the tub may be too full..
Nov 14, 2013 | Pool & Spa
Rod
US Parts Center
888-521-6183
Mar 31, 2013 | Pool & Spa
I have a sundance spa 880 that does not start. The control panel shows only a broken line and nothing else.
When you say broken line, do you maybe mean " - - - - " like 4 dashes?
That is called a Watchdog, where the spa internal smart circuitry has sensed a potential damaging problem. Many things could be causing this. If you turn power off and upon re-energizing power, push jets button. Does it come on? This needs to happen immediately after powering up. Using a 2nd person is a great asset in this.
Jan 15, 2013 | Pool & Spa
Aug 08, 2012 | Pool & Spa
Have an emerson spa motor in my sundance hot tub it runs for 2 min. and cuts off I think it is overheating. what do you think it is,
do not run it , get it repaired , the start switch is stuck or it has a bad capacitor.. keep running it yo stand the chance of burning up the motor . TAKE NOTES ON HOW THE WIRES GO !!!! jay.. pump guy in longwood fl
May 15, 2011 | Emerson Pool & Spa
On the sundance spa optima the watchdog error came on the control board a few seconds after the hottub was turned back on after refilling, how can i fix this?
Nov 27, 2010 | Optimus Pool & Spa
I have an older Sundance Sentry Spa model 605. Over time, I have a problem with the 20A GFCI heating to the point where the insulation on the load wire connected to the GFCI becomes discolored. My Spa...
Aug 09, 2010 | Leviton 8599 GFCI Receptacle
I have a Sundance Spa that has started tripping the breaker
It is unlikely the Breaker is BAD, that just doesn't happen. To trip a breaker there MUST be an Overload, or a Short circuit, that's it. You will have to use a meter an troubleshoot the system. Something is very wrong..please use the links below to troubleshoot and repair. Please Be careful. http://spababes.com/heaterhelp.html
http://www.spadepot.com/spacyclopedia/spa-heater-element.htm
http://www.poolandspa.com/page596.htm
May 07, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Kitchen Ranges Logo
144 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
