Question about Freezers
I require a wiring dia for kelvinator N395BGWH no frost model
As above,
replacing components and want to check existing wiring to eliminate fault
  • 828 Answers
What is the fault you are trying to eliminate? There is a possibility that the fault is other than in the wiring. Check on the back of the unit as wiring diagrams are sometimes attached to the back wall of the refrigerator.
Posted on May 16, 2008
Chest freezer only freezing at the bottom half of freezer but the goods in the basket aren't frozen, its a year old
Going to have to assume a lot of things... because you put no make or model... (such as self defrosting).
After you have checked that there is NOT excessive FROST BUILD UP (prevents air flow & causes same symptoms...
(defrost issue: different trouble ... comment me back)
Without any mention of EXCESSIVE FROST (which would indicate poor door seal/alignment...
(Not DEFROST FAILURE (dry defrost pan)...
That leaves us with your EVAP FAN...
There are a couple of reasons evaporator fans fail:
(you just eliminated old age in your question... "year old")
- Defective is still a possibility (replace)
- Ice/frost blocked (Full manual DEFROST)
- Physical blockage ((inspect: usually wire or POOR install.
Check your manufacturer's parts list and shop around for the BEST PRICE... There NO variances in quality (just price).
GOOD freezers work because of excellent air flow...!!
And ALWAYS REMEMBER TO TAKE PICURES & REMOVE POWER BEFORE fiddling with every appliance.
Good luck...
(I check in daily... Please do comment if you need me)
Carnac the Magnificent
Feb 04, 2017 | Freezers
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
Freezer not working
  • Make sure the freezer is plugged in
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for voltage
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outage votageIf power is reaching the electrical outlet, trace the freezer wiring and test components as you go. Either there is a short, which must be located and repaired, or the freezer has sustained electrical damage.
Thanks.
Jun 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Major Appliance
It sounds like the thermostat is not sensing when the fridge/freezer reaches it's set temperature.This will result in the compressor running non-stop and this causes ice build-up inside the fridge.See on what number (0-7) the thermostat is set on.If it is set on 7,turn it down to 3 and see if it makes a difference.If there is no difference it means that the thermostat is not sensing & switching the compressor off.You will then have to replace the thermostat.
Regards
Andre Nagel
Mar 15, 2010 | Freezers
My frost free freezer keeps frosting up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 28, 2009 | Electrolux Freezer Kelvinator Single Door...
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
142 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
