Question about Whirlpool LGR4634J Gas Dryer
How do you get to the igniter - Whirlpool LGR4634J Gas Dryer
    President:
  • 1,218 Answers
Good day,
Remove the lint screen. There are 2 screws under it. Remove the screws.
With a screw driver, pop up the lid one side at a time. It's held down with clips.
Rotate the lid away from you. You will see a screw on the inside top on each side of the front panel. Remove the screws and wires to the door switch.
Pull the front toward you a little and lift the whole front off the bottom clips. Set it aside.
On the bottom left you will see the gas valve and heat tube.
The ignitor is located away from you extending into the heat tube.
It is held on with a wire plug, and one screw. If your replacing the ignitor do not touch the silicone carbide section of the ignitor with your fingers. Oil from you skin will ruin it.
If your problem is no heat, I would remove the back cover first.
Look at the center bottom. You will see a skinny white thermal fuse. it is held on with one screw and is the most common cause for no heat on your model.
It looks like this, and should check out at zero ohms with an ohm meter.
Posted on Sep 15, 2010
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Jan 20, 2016 | Kenmore Kitchen Ranges
Oven and broiler won't work surface burners ok
Troubleshooting Why Your Gas Oven Won Ignite or Heat PartSelect com
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
Dec 05, 2015 | 2001 Cadillac DeVille
Ignition switch diagrams
12V CONSTANT YELLOW Ignition Harness
STARTER WHITE/PINK Ignition Harness
IGNITION RED/LT. GREEN Ignition Harness
ACCESSORY GRAY/YELLOW Ignition Harness
SECOND ACCESSORY BLACK/GREEN Ignition Harness
also this might be of some interest to you if you are having ignition switch problems just look up this FORD ignition switch recall
NHTSA recall number 96V-071).
Aug 04, 2014 | 1990 Ford Taurus
I have a 98 Chevy Malibu Ls and the ignition won't
Inspect the old ignition cycle which is out.Is there any problem noticed of Ignition cylinder getting worn out.
Because when issue of ignition not turning off,its faulty ignition lock cylinder or faulty ignition switch.I suggest re-inspect the new ignition cylinder.
For more help,click the help link mentioned below:----
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
Kexus ignition switch replace
To troubleshoot these issue, for ignition switch replacing procedure:---
Click the link below:---
IGNITION SWITCH REPLACING
It depends on vehicle to vehicle. But it's not very difficult on mot of cars to replace ignition switch. Basic theory of replacing ignition switch is same for all car models. -----
To replace ignition switch on your vehicle, I suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.
Click the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
Ford Taurus: Ignition Switch & Steering Column Replacing?
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
These will help.
Thanks.
Dec 06, 2012 | 1993 Lexus Es 300
How to replace ignition switch
It depends on vehicle to vehicle.But its not very diffult on mot of cars to replace ignition switch.Basic theory of replacing ignition switch is same for all car models.:-----
To replace ignition switch on your vehicle,i suggest you few helplinks with proper ignition switch replacing procedure. View its details and you can replace ignition switch on your vehicle.-------------Click the link below :----------------
1995 Ford Taurus: Ignition switch not turning OFF? http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Switch Will Not Turn Off? http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
These will help.
Thanks.
Nov 25, 2012 | Cars & Trucks
How do i change the coil
Ignition Coil Removal
  1. Disconnect fuel charging wiring connectors from ignition coil (12029) and radio ignition interference capacitor (18801) .
  1. Disconnect ignition wires by squeezing locking tabs and twisting while pulling upward. e941a97.gif
  2. Remove four ignition coil retaining screws and remove ignition coil and radio ignition interference capacitor . Save radio ignition interference capacitor for installation with ignition coil .
Installation
  1. Position ignition coil and radio ignition interference capacitor to ignition coil mounting bracket.
  1. Install retaining screws and tighten to 4.5-7.0 Nm (40-61 lb-in).
  1. Apply Silicone Dielectric Compound D7AZ-19A331-A (Motorcraft WA-10) or equivalent meeting Ford specification ESE-M1C171-A to all ignition wire boots.
  1. Install each ignition wire connector to the proper terminal on the ignition coil . Make sure boots are fully seated.
  1. Connect fuel charging wiring (9D930) to the ignition coil and radio ignition interference capacitor .
May 10, 2010 | 1998 Ford Windstar
How do i put a coil in a 2001 jaguar s type
303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual DESCRIPTION AND OPERATION Engine Ignition The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L 2001 Lincoln LS Workshop Manual
v-8
REMOVAL AND INSTALLATION Ignition Coil Removal
  1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
  1. Remove the bolts and the ignition coil cover.
  1. Disconnect the electrical connector from each ignition coil.
  1. Remove the ignition coils.
    1. Remove the bolts.
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual
  1. Remove the engine appearance cover.
  1. To access the RH bank ignition coils, remove the upper intake manifold. For additional information, refer to Section 303-01A .
  1. Disconnect the electrical connector from the ignition coils.
please rate as fixed if this helps.
Apr 28, 2009 | 2001 Jaguar S-Type
1991 Dodge Spirit ignition problem
The "SPRING-BACK" Action is Originated in the Ignition Switch itself (THE ELECTRICAL SWITCH) I think that is where you should Look. On these models, the ignition lock and ignition switch are removed as an assembly. Refer to IGNITION LOCK .
Disable airbag, refer to Air Bags and Seat Belts/Air Bags (Supplemental Restraint Systems)/Service and Repair . After procedure has been completed, rearm airbag system.
  1. Disconnect battery ground cable.
  2. Remove tilt lever.
  3. Remove three Torx column cover attaching screws, then the upper and lower column covers.
  4. Using tamper proof Torx bit tool No. 440-TX20H or equivalent, remove three ignition switch mounting screws.
  5. Carefully pull switch away from column. Release two connector locks on seven terminal wiring connector, then disconnect from ignition switch.
  6. Release connector lock on four terminal connector, then disconnect from ignition switch.
  7. Remove ignition lock from ignition switch as follows:
    1. With key inserted and switch in Lock position, use a small screwdriver to depress ignition lock retaining pin flush with lock cylinder surface.
    2. Rotate key clockwise to Off position. Ignition lock should now be unseated from ignition switch assembly. Do not attempt to remove ignition lock at this time.
    3. With ignition lock in unseated position (lock bezel approximately 1/8 inch above halo light ring), rotate key counterclockwise to Lock position, then remove key.
    4. Remove ignition lock from ignition switch.
  1. Reverse procedure to install, noting the following:
    1. Connect two wiring connectors to ignition switch. Ensure switch locking tabs are fully seated in connectors.
    2. Install ignition switch on steering column.
    3. On column shift models, shift lever must be in P position and park lock dowel pin on ignition switch assembly must engage with column park lock slider linkage.
    4. On all models, verify ignition switch is in Lock position (flag parallel with ignition switch terminals).
    5. Apply a dab of suitable grease to flag and pin, then position park lock link and slider to mid-travel.
    6. Position ignition switch against lock housing face. Ensure pin is inserted into park link contour slot.
    7. Install ignition switch retaining screws and torque to 12-22 lb-in .
    8. With ignition lock and switch in Lock position, insert ignition lock into ignition switch until it bottoms.
    9. Insert key, then while carefully pushing ignition lock toward ignition switch, turn key clockwise to Run position.
    10. Check for proper operation on ignition switch in all positions.
FOR PICTURES EMAIL ME AT MY NICKNAME HERE ON FIXYA @AOL.COM
Feb 12, 2009 | 1991 Dodge Spirit
Whirlpool LGR4634J Gas Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
