Question about Coleman Powermate Powermate 5000W Generator
Coleman generator model#PCO401850 , what fuel does it use
    Genius:
  • 1,739 Answers
Find the model number of your generator.
Search the list at the following site for the Manual for your generator:
http://www.powermate.com/productmanuals.php?cat_id=3
The manual will provide information on the fuel to be used for your specific model.
Sorry someone has not gotten back to you sooner.
Posted on Jun 28, 2011
Generator starts but only runs for 1 or two minutes then dies
Check oil pressure and sender, check fuel pressure and fuel solenoid. Check stator resistance and output voltage. Manuals can be found by contacting:
http://www.advanced-power-technologies.com/coleman-power-station-generator.php
Dec 12, 2013 | Powermate Coleman Standby Generator...
My Coleman 3750 generator normally starts on the 1 st or 2 nd pull. It will not keep running unless continue tom choke it?????
You have a lean fuel condition. Your carb is slightly clogged. By choking the unit you are manually changing the air/fuel ratio to richen up the mix. Your carb needs to be removed and cleaned. Hope this info helped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 07, 2013 | Coleman Cable COLEMAN POWERMATE PM0433750...
My coleman powerhouse dual fuel lantern brightens and dims continuously. could this be the generator acting up?
Hi bradley m925...
Try using the cleaner for the generator, it is a twist type crank, make a few turns on it if you have it.
If not then your right, replace the generator as it is faulty.
Please take time to rate me
Coleman Generators website...http://www.summitcampinggear.com/lage.html
Sep 21, 2011 | Coleman Cable Coleman Twomantle Dual Fuel...
Where can i find a fuel cap for a coleman powermate sport generator model 0401851.
This generator model was made with 2 different engines
Just using the model number without crossing to an engine it says the Cap PN is: 0049841
Call Coleman at 1-800-445-1805
($10.33)
http://arkansas-ope.com/93400-ms0323-0603.pdf
and
http://arkansas-ope.com/91400-ms7152-0603.pdf
Another source for PN: 0049841
Welcome to Generator Parts ' Generator Systems, LLC.
Generac Parts, Briggs & Stratton Parts and Coleman Powermate Parts.
Can't Find it? Contact us with your generator Make, Model and Part Information.
Call 1-888-207-2169 EXT 3
Email:parts@generatorsystemsllc.com
Let me know if you still can not find a replacement and I will look for more sources.
Thanks for choosing FixYa,
Kelly
Aug 17, 2011 | Electrical Supplies
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Sep 27, 2009 | Coleman Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
113 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
