Question about Toshiba Satellite L505D Notebook
Toshiba l505d reset bios i pulled the small battery for a day and when i put it back together it say press F1 continue or F2 FOR setup when i press either F1 or F2 it goes back to asking me for the password do you have any suggestions
  • 393 Answers
It's very Easy.. remove ram cover near the ram u can see small jumper short the jumper for 15 second with flat screw driver.. if same ..do again but keep short jumper and turn on laptop for 15 second .... Thanks if okie give me vote
Posted on Sep 15, 2010
Testimonial: "now it asking for a HDD #1/ssd password i don't know what that is do SIM"
  • 3 more comments
  • Shahzad Iqbal
    Shahzad Iqbal Sep 16, 2010
    SORY FOR HDD PASSWORD CAN'T BREAK PASSWORD .. I KNOW 1 WAY .. IF U REAL DONT WANT TO LOSS UR DATA .. BUY THE SAME HDD NEW ONE REPLCE THE MAINBOARD ... THAT'S IT Thanks
  • adllift Sep 17, 2010
    if i don't care about the data being lost is there a way to bypass the hhd password
  • Shahzad Iqbal
    Shahzad Iqbal Sep 18, 2010
    only on way u need to cahnge mainboard of HDD if u need your data back... HDD mainboard should be 100% same ... model and capacity.. Thanks
  • fr0st42 Sep 18, 2010
    So I need to short the 2 solder spots over the white rectangle to do this? I tried a couple times and I still have the computer asking for a bios password. Would it be possible to take a picture of the solder points?
  • fr0st42 Sep 23, 2010
    B600 is the solder point and it's under the memory stick so it's real easy to get at.
    Go here for detailed instructions and photos...
    http://www.hardwareanalysis.com/content/...
I need to short the 2 solder spots over the white to do this? I tried a couple times and I still have the computer asking for a bios password.
Posted on Sep 18, 2010
    delete this solution I posted in wrong area. Thanks
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
How to do i enter bios setup in toshiba 5205-s705
Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS.
With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message.
Hope this info helps.
May 19, 2012 | Toshiba Satellite 5205-S705 Notebook
Toshiba satellite pro sp2100 -> Mod No: ps210E
TOSHIBA
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 15, 2011 | Toshiba Computers & Internet
When i power my computer up, its telling me to press f1 to continue or f2 to setup. I pressed f1 and it is asking me for a password. What is the password?
Ok this means that somebody has set a bios password on your computer, But we can fix this for you. I will try and explain this for you.
"The reason the computer is asking you to press F1 is because some settings in the Bios are not correct, such as memory size is incorrect or processor speed is not right, So what you need to do is un-plug the computer and once it is unplugged take open up the computer by removing the case or side to have access to the motherboard, once you see the motherboard locate the battery backup which will be similar to the picture below. Once you locate the battery, take it out, Now with the battery out press and hold the power button in for about 3-5 seconds to discharge the remaining power from the system. Once you have done this re-insert the battery and put the computer case back on and plug it back in and press the power button. You will then be prompted with the Press F1 to continue screen since we reset everything now, so you will want to press F2 to enter your bios in which should not have a password now, Once you are in the bios screen which should be a blue screen, look for the option to set to default usually its like F12 or some key like that but not sure on your system. Once you restore to default make sure to save changes and restart the computer and you should be all set and not have the F1 to continue screen any longer. I hope this helps.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Replace CMOS battery
First you need to take the cover off your laptop and locate the cmos battery which looks like an oversize battery watch. With everything unplugged it just pulls out, note which side of the battery goes however. Place the new one in put everything back together and power the computer up. When it powers up it will finally get to the screen that says press "F1" for setup or "F2" to continue. Press F1 and you will get to your set up screen. You can go through each screen and select F5 which is the default factory settings or scoll across the top to the last screen which will give you the option of resetting all the settings to factory default with just pressing one of the F keys once only. Once you do that, just shutdown your computer and restart and it will start as normal. It may go through the F1 and F2 screen one more time but just press F2 and continue. After you log off the next time all your changes should be good. Let me know if I can help you in any other way.
Jan 25, 2009 | NEC Versa VX Notebook
Booting up my d600 laptop
This problem can be caused by two reasons:
1) The CMOS battery is damaged or displaced ( apart from the external battery, there is a small battery which is connected to the motherboard)
2) One of the RAM modules is displaced.
First make sure that the laptop displays the amount of RAM correctly. You do this by opening Control Panel -> System and noticing the amount of RAM.
If it is okay then press F2 when your computer starts of to enter bios. Make sure that the date and time displayed are okay, if not change them accordingly. Then Save the CMOS and exit.
If nothing changes then let me know
Nov 24, 2008 | Dell Latitude D600 Notebook
Bios
To enter the BIOS, press the Esc key when the Toshiba script shows up on the display. You should then get a message to press the F1 key to continue. Press the F1 key and you should be in the BIOS. The Boot sequence is on Page 2 of the Bios settings on many Toshibas. To get to page 2 press the page down key. Make sure you follow the screen prompts because your system may be slightly different.
Please rate this, thanks
Jun 25, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite L505D Notebook Logo
1,939 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
