Question about Maytag NFW7200TW Front Load Washer
Amana nfw7200tw front load washer - 16 months old- door sags and must be lifted to close and engage latch - noticed at about the 1 year mark when warranty expired , the hinges are not obviously slotted for adjustment, anyone knowledgeable on the repair?
4 Suggested Answers
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Posted on Dec 11, 2010
  • 92 Answers
SOURCE: the door is open, but the latch is in a locked position.
it sounds like the child lock as been turned on,check the handle part to see if it as a **** in it were you can turn it with a screwdriver just turn this upwards or sidewards to see if the door will lock or open ?.rgrds,paul
Posted on Jul 07, 2009
richroth
  • 9472 Answers
SOURCE: My Amana NFW7200TW front loader Washer door is
You need to replace the door. Here is a link to the part you will need.
Posted on Dec 24, 2010
Amana washer error code
This is an open door error. check the latch and switch on the machine.
Feb 05, 2014 | Washing Machines
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
NFW7200TW hums and does not turn or fill with water
if it doesn't fill the water valve will hum,first thing is to see if it's a problem with the house water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Door latch stays locked
remove the top and there is a manual release for the door near the latch. You will need to replace the door lock. Here is a link to the part.
Oct 17, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Amana washer model NFW7200TW drain filter
Go to www.repairclinic.com and enter NFW7200TW. You will be presented with a list of common repair parts and may be able to view a generic Amana video showing disassembly and parts identification.
May 17, 2012 | Washing Machines
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Feb 25, 2009 | Amana Washing Machines
NFW7200TW washer won't engage spin cycle
We had the same problem with the same model machine and solved it.
Our machine was a month old and started getting stuck at minute 8, so we arranged service calls through Amana customer service. Long story short, the first three service reps couldn't figure out the problem. Two of them called Amana's in-house tech support line and the Amana techs didn't know what the problem was. The fourth repairman was smarter than his predecessors. He called the Amana in-house tech line, spoke to a rep who didn't know what was wrong, and then called in again. He explained that. based on his experience, some in-house techs knew more than others. That turned out to be the case because on his next call-in to Amana, that rep knew exactly what the problem was and recommended replacing the main computer board module. The repair guy ordered and installed the part. The machine has been working perfectly for a month.
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Maytag NFW7200TW Front Load Washer Logo
274 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
