Question about LG DLG5988 Gas Dryer
Cooling light lit--only blowing cool air--filter light on when first selecting setting--all clean--disassembled and vacuumed out--still not heating
    Master:
    Sergeant:
  • 449 Answers
Check the ignitor
Posted on Sep 15, 2010
I HAVE REMOVED THE AIR FILTER WHICH IS BLACK WITH DUST, HOW SHOULD I CLEAN IT? WITH WHAT SHOULD I CLEAN THE AIR FILTER, WATER OR GASOLINE OR SOMETHING ELSE?
You don't say what the filter is in but never gasoline, unless it is an engine air filter in a vehicle, and then only one that is foam and reusable. Typically, blow with an airline, only do that once or twice and then buy new.
Home filters for furnaces, heating? Buy new.
Vacuum cleaners, wash in soapy water, shake and dry thoroughly.
Air purifiers, same as above.
Mar 28, 2017 | Filter Heating & Cooling
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Unit comes on and shut off correctly but dosen't heat and cool home equally. Blows cold air in winter and doesn't cool home properly in summer.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 09, 2011 | Intertherm Heating & Cooling
LG neo plasma air conditioner does not blow cold air
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
My Kenmore 72059 unit is blowing cold air but is not cooling the room (the room is not the big either). It is set at 60 degrees. Why is the room not getting cool?
Physics, friend.
Ideally any cool input would be enough to effect the temperature, but other things are working against you.
Check the air filter behind the case cover and clean it if necessary. This may improve your air flow. While you have the cover off, look at the coils, and make sure that they aren't iced up or plugged. During peak humidity periods or when the refrigerant level is low, icing can occur. If you have a recirculating/outside air option, try to partially select outside air. In a well sealed room, with the selection of 100% recirculation, moisture can build up in the room. By setting it on 60, you may be asking it to do more than it is physically capable of.Dirt generally just happens, but can be cleaned. Provided that all's well that you have checked, look for other cool-robbing sources. Windows can be a huge source of heat gain in a room, particularly those that receive late afternoon sun. Light colored blinds reflect some of the heat, Other factors that can affect your heat gain might include openings or cracks around windows and doors, and the state of your insulation in your walls and attic. Assess your area for leakers and hit the biggest offenders first. You can do a rough assessment to locate heat gain with your hands by moving around the room and feeling for heat. Significant amounts of heat can be felt by touching the walls, ceiling, etc. Open vents can have a profound effect. If you have a fireplace, is the damper closed? That sort of thing. All things to consider.
Hope that this has been useful to you.
Regards, --W/D--
Jul 17, 2009 | Kenmore 72059 Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
LG DLG5988 Gas Dryer Logo
289 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
